Product
Brand
Epson EH-TW6600 1920X1080 3LCD HD 3D Home Projector
Quicklinx: C264WS00 Mfr#: V11H651040LU
Sharp and bright images
This Full HD projector uses 3LCD technology and 2,500 lumens brightness, with equally high White and Colour Light Output, to ensure vivid colours with no rainbow effect, while the 70,000:1 contrast ratio means deep blacks and highly detailed images in dark scenes.
Easy positioning
With wide vertical and horizontal lens shift, it's easy to position the EH-TW6600 off-centre to a screen, creating a precisely-sized image, with no distortion or stretching. Combined with a 1.6x zoom lens and a compact design, it makes it incredibility simple to set up in any environment. Integrated 20W stereo speakers free you to connect to any external system, while all audio can easily be sent to a sound system using dedicated outputs.
Advanced imaging technology
Able to convert 2D video to 3D for maximum versatility, the EH-TW6600 includes seven colour modes – including two specially for 3D – and a pair of RF 3D glasses . By sensing the ambiaent light levels, the auto colour optimiser can automatically identify the best setting, and Epson's enhanced Super Resolution ensures both 2D and 3D video looks as sharp and crisp as possible.
Epson EH-TW6600 - 3LCD projector - 3D
3LCD projector - High Definition 1080p
3D Capable
Yes (3D glasses included)
Built-in Devices
Stereo speakers, 0.61-inch LCD
Brightness (White)
2500 lumens
Brightness (Colour)
2500 lumens
Contrast Ratio
70000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Horizontal, vertical
Bulb type
UHE 230 Watt
Video Input
RGB, composite video, component video
Speakers
Speaker(s) - integrated
366 Watt
41 cm x 30.4 cm x 15.7 cm
6.8 kg
2 years warranty
3LCD projector - HD 1080p
3D Capable
Built-in Devices
Projector
Brightness (White)
2500 lumens
Brightness (Colour)
2500 lumens
Contrast Ratio
70000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
0.87 m - 14.5 m
Throw Ratio
1.32 - 2.15:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Bulb type
UHE 230 Watt
16:9 aspect ratio support, Split Screen, Dynamic Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Factor
1.6x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Vertical Lens Shift
60% / 60%
Horizontal Lens Shift
24% / 24%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, MHL
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 1 x component video input - RCA x 3 , 1 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
WirelessHD Transmitter Set, wireless remote control
Security Features
366 Watt
Power Consumption Stand by
0.43 Watt
41 cm
30.4 cm
15.7 cm
6.8 kg
Limited warranty - 2 years , Limited warranty - lamp - 1 year / 750 hours
Sound Emission
32 dB
24 dB
