Epson EH-TW570 WXGA 1280x800 HD 3D Home Projector
Quicklinx: C260WS00 Mfr#: V11H664040LU
Bright 2D & 3D images
At 3,000 lumens the EH-TW570 is Epson's brightest home cinema projector. Producing exceptional images whatever the ambient light levels, the EH-TW570 projects in both 2D and 3D, even converting 2D video into 3D. Choose from four colour modes (Living room, Dynamic, Theatre and Game) and two colour modes while watching in 3D, with three brightness levels available.
Improved contrast
An improved contrast ratio of 15,000:1 allows the EH-TW570 to deliver sharp images, while 3LCD technology ensures a equally high White and Colour Light output and no rainbow effect for beautiful colour images.
Easy to use
Vertical and horizontal keystone correction and 1.2x zoom make it simple to position the projector where you want it. Integrated stereo 2W speakers lessen the need for a separate sound system, while audio outputs on the EH-TW570 bring more versatility. It also benefits from a long lamp life of 5,000 hours in normal mode, and 6,000 hours in eco mode.
Great gaming
Big screen gaming has never been so responsive; a special game mode called Turbo reduces lag time so you'll never miss that shot.
Greater sharing
Epson's iProjection app allows touchscreen devices to easily share content, while a QR code displayed by the projector makes connecting devices even easier. HDMI-MHL connectivity makes it easy to directly connect smart devices.
  • HD-ready projector
    Epson's brightest home cinema product, this great value 3,000 lumen projector uses 3LCD technology for sharp, smooth images in 2D and 3D.
Epson EH-TW570 - 3LCD projector - portable - 3D
3LCD projector - 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
0.59-inch TFT LCD
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
15000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
200 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video
Speakers
Speaker(s) - integrated
270 Watt
29.7 cm x 7.7 cm x 23.4 cm
2.4 kg
3D Capable
Built-in Devices
0.59-inch TFT LCD
Projector
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
15000:1
Image Size
84 cm - 812 cm
Projection Distance
1.68 m - 3.4 m
Throw Ratio
1.3 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
240 Hz
Bulb type
200 Watt
Bulb life cycle
3LCD Technology, Split Screen, 16:10 aspect ratio support, Game mode, Dynamic Mode, MHL compliance
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Speakers
Integrated
Output Power / Channel
2 Watt
1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm
Remote control
270 Watt
Power Consumption Stand by
3 Watt
29.7 cm
7.7 cm
23.4 cm
2.4 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
Sound Emission
37 dB
29 dB
C260 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
