Bright 2D & 3D images
At 3,000 lumens the EH-TW570 is Epson's brightest home cinema projector. Producing exceptional images whatever the ambient light levels, the EH-TW570 projects in both 2D and 3D, even converting 2D video into 3D. Choose from four colour modes (Living room, Dynamic, Theatre and Game) and two colour modes while watching in 3D, with three brightness levels available.
Improved contrast
An improved contrast ratio of 15,000:1 allows the EH-TW570 to deliver sharp images, while 3LCD technology ensures a equally high White and Colour Light output and no rainbow effect for beautiful colour images.
Easy to use
Vertical and horizontal keystone correction and 1.2x zoom make it simple to position the projector where you want it. Integrated stereo 2W speakers lessen the need for a separate sound system, while audio outputs on the EH-TW570 bring more versatility. It also benefits from a long lamp life of 5,000 hours in normal mode, and 6,000 hours in eco mode.
Great gaming
Big screen gaming has never been so responsive; a special game mode called Turbo reduces lag time so you'll never miss that shot.
Greater sharing
Epson's iProjection app allows touchscreen devices to easily share content, while a QR code displayed by the projector makes connecting devices even easier. HDMI-MHL connectivity makes it easy to directly connect smart devices.
HD-ready projector
Epson's brightest home cinema product, this great value 3,000 lumen projector uses 3LCD technology for sharp, smooth images in 2D and 3D.
- Epson EH-TW570 - 3LCD projector - portable - 3D
- 3LCD projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- 0.59-inch TFT LCD
- Brightness (White)
- 3000 lumens
- Brightness (Colour)
- 3000 lumens
- Contrast Ratio
- 15000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 200 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - integrated
- 270 Watt
- 29.7 cm x 7.7 cm x 23.4 cm
- 2.4 kg
- 2-year warranty
- 3D Capable
- Built-in Devices
- 0.59-inch TFT LCD
Projector
- 3000 lumens
- 3000 lumens
- Contrast Ratio
- 15000:1
- Image Size
- 84 cm - 812 cm
- Projection Distance
- 1.68 m - 3.4 m
- Throw Ratio
- 1.3 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Max Sync Rate (V x H)
- 240 Hz
- Bulb type
- 200 Watt
- Bulb life cycle
- 3LCD Technology, Split Screen, 16:10 aspect ratio support, Game mode, Dynamic Mode, MHL compliance
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Output Power / Channel
- 2 Watt
- 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Remote control
- 270 Watt
- Power Consumption Stand by
- 3 Watt
- 29.7 cm
- 7.7 cm
- 23.4 cm
- 2.4 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
