Epson EH-TW5650 LCD 3D Projector
Quicklinx: DGTNWS00 Mfr#: V11H852041
Make every moment count
With this Full HD home cinema projector you can create the big screen experience with images reaching up to 300 inches (762cm). It can handle the most atmospheric scenes with clearly defined shadow detail and deep blacks, while also remaining clear, sharp and smooth during high-action scenes with Detail Enhancement and frame interpolation.
Simple set up
The compact and lightweight EH-TW5650 is easy to move, plus the vertical lens shift, 1.6x zoom and keystone correction ensure it's fuss free to position the picture. It features two HDMI inputs (including one MHL) for connecting DVD players, games consoles and more. Use smart devices to operate the projector; the iProjection app can control the projector and Miracast lets you share content over a wireless connection with Android devices.
11 years of entertainment
Looking for a long-term, hassle-free and affordable solution for your entertainment needs? With the EH-TW5650, you could watch a film every day for 11 years thanks to the long-lasting lamp light source .
Experience vivid and lifelike images
Epson's 3LCD technology radiates exceptionally bright yet colourful images by producing an equally high White and Colour Light Output. Even in bright living rooms, this Full HD 1080p projector delivers 2,500 lumens and a 60,000:1 contrast ratio.
  • 1080p home cinema projector
    Create the cinema experience at home with this easy to set up, Full HD, home cinema projector with lens shift.
Epson EH-TW5650 - LCD projector - 3D - 802.11n wireless / Miracast - white
LCD projector - 1080p
3D Capable
Yes (3D glasses sold separately)
White
Built-in Devices
Speaker
Brightness (White)
2500 lumens
Brightness (Colour)
2500 lumens
Contrast Ratio
60000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
UHE 200 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 7500 hour(s) - economic mode
Video Input
RGB IEEE 802.11n wireless / Miracast
Video Modes
1080p
Speakers
Speaker(s) - integrated
296 Watt
30.9 cm x 28.5 cm x 12.2 cm
3.5 kg
3D Capable
Built-in Devices
Speaker
802.11b/g/n
Enclosure Colour
White
Projector
Brightness (White)
2500 lumens
Brightness (Colour)
2500 lumens
Brightness (Reduced)
1650 lumens
Contrast Ratio
60000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
2.35 m - 3.82 m
Throw Ratio
1.33 - 2.16:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Bulb type
UHE 200 Watt
Bulb life cycle
Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Dynamic Mode, Theater Mode, 3x Brighter Colors, Bright Cinema
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI, MHL
Video Modes
1080p
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x HDMI input - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm
Wireless remote control
Security Features
Power Source
AC
296 Watt
Power Consumption Stand by
0.2 Watt
30.9 cm
28.5 cm
12.2 cm
3.5 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
Sound Emission
37 dBA
27 dBA
