Sharp, smooth images for the best looking films and TV
Using Epson's 3LCD technology for exacting brightness and colour, this Full HD projector features high White and Colour Light Output of 2,200 lumens and 30,000:1 dynamic contrast ratio. Together this technology ensures bright, vivid colours and deep blacks. Frame interpolation and Detail Enhancement provide sharper and smoother motion pictures and great detail, for greater clarity, and the EH-TW5210 can also convert standard 2D video into 3D.
Enjoy the big-screen experience with easy set-up
Aimed at people who want a truly big-screen experience at home to watch films, TV and sports, this projector delivers stunning Full HD entertainment at up to 332 inches. Positioning your projector to get a perfectly-aligned image is easy thanks to keystone correction.
Built-in speaker
Though it's primarily designed to be used with a separate sound system, an integrated 5W speaker on the EH-TW5210 makes initial set-up of the projector simple.
Home cinema projector
Enjoy the big-screen experience at home and watch a movie every day for the next 11 years with this affordable but powerful projector.
- Epson EH-TW5210 - LCD projector - portable - 3D
- LCD projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness (White)
- 2200 lumens
- Brightness (Colour)
- 2200 lumens
- Contrast Ratio
- 30000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 200 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 7500 hour(s) - economic mode
- Video Input
- RGB, composite video
- Video Modes
- 1080p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 291 Watt
- 29.7 cm x 24.5 cm x 11.4 cm
- 2.9 kg
- 2-year warranty
- 3D Capable
Projector
- 2200 lumens
- 2200 lumens
- Brightness (Reduced)
- 1500 lumens
- Contrast Ratio
- 30000:1 (dynamic)
- Image Size
- 86 cm - 843 cm
- Throw Ratio
- 1.22 - 1.47:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Bulb type
- 200 Watt
- Bulb life cycle
- Auto Vertical Keystone, 16:9 aspect ratio support, Split Screen, Dynamic Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
- Video Modes
- 1080p
Speakers
- Integrated
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2
- Included Accessories
- Wireless remote control
- Security Features
- Power Source
- AC
- Voltage Required
- 291 Watt
- Power Consumption Stand by
- 0.28 Watt
- Software Included
- EasyMP Network Projection
- 29.7 cm
- 24.5 cm
- 11.4 cm
- 2.9 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
- 0 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 27 dBA
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
