Cartridge-free printing
This next generation EcoTank is a fast 4-in-1 with a 250-sheet paper tray. It can reduce printing costs by 90% on average (1).
Cut your printing costs with Epson’s cartridge-free EcoTank. This 4-in-1 inkjet can reduce printing costs by 90% on average (1). Delivering a ultra-low-cost per page, it can print 14,000 pages in black and 11,200 in colour (2). It has a range of features including Wi-Fi, double-sided printing, a 250 sheet front tray, 30 page ADF, fax and fast 15ppm (4) print speeds.
Key Features
- Ultra-low-cost per page: Reduce ink costs by 90% (1)
- Thousands of pages' worth of ink1: Print up to 14,000 pages in black and 11,200 pages in colour (2)
- Next generation ink filling system: Enjoy hassle and mess-free refills with the enhanced ink bottles
- Mobile printing and connectivity: Wi-Fi, Wi-Fi Direct, Ethernet & free mobile printing apps (4)
- Designed for business: 250 sheet front tray, fax, 30 page ADF and double-sided printing
(1). Average number of cartridges/savings for printing the number of pages using the bundled ink bottles with the EcoTank range, excluding hardware price. Comparison made on the average of the A4 EcoTank range versus the average of the top 10 best-selling models in Western Europe, in the period January 2017– December 2017, as tracked by GfK. Printing costs calculated on the proportion of Standard and XL cartridges as tracked by GfK for the same reference period for the Western European market, using average retail prices. Ink cartridge yields as communicated by the manufacturer’s websites. (2). Quoted yields are extrapolated based on Epson original methodology from the print simulation of Test Patterns provided in ISO/IEC 24712. Quoted yields are NOT based on ISO/IEC24711. Quoted yields may vary depending on the images that you are printing, the paper type that you are using, the frequency of your prints and environmental conditions such as temperature. During the initial printer setup, a certain amount of ink is used to fill the print head's nozzles, therefore the yield of the initial bundled set can be lower. (3). Determined in accordance with ISO/IEC 24734 showing the average of ESAT from the Office Category Test for default simplex. For more information visit www.epson.eu/testing (4). Requires a wireless connection to the internet. For more information, supported languages and devices please visit www.epsonconnect.eu
Ultra-low cost
EcoTank can slash printing costs by 90% on average thanks to its innovative design. It features an ultra-high-capacity ink tank that completely removes the need for cartridges. This model comes with an additional set of ink bottles. -
Print thousands of pages
Get more prints between refills. Thanks to the ink included in the box, it can print 14,000 pages in black and 11,200 in colour. -
Discover the next generation of EcoTank
With the ink tank now housed at the front, EcoTank is more compact and easier to use than ever before. Protecting you against leaks and spills, it features an enhanced ink filling system engineered for mess-free refills. The new bottles also incorporate a mechanism to ensure that only the correct colours are inserted. -
Print from almost anywhere
With Wi-Fi and Wi-Fi Direct, send documents to print from smart devices using the Epson iPrint app. It can even receive files from almost anywhere in the world via Epson Email Print.
- Epson EcoTank ET-4750 - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Max Printing Speed
- Up to 15 ppm (mono) / up to 8 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 250 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB, LAN, Wi-Fi
- AirPrint Enabled
- Power
- AC 230 V (50/60Hz)
- 37.5 cm x 34.7 cm x 23.1 cm
- 4.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Colour Support
- Display Features
- Touch screen
- Interface
- USB, LAN, Wi-Fi
- AirPrint Enabled
Printing
- Inkjet Technology
- Nozzle Configuration
- 400 nozzles (black), 128 nozzles (per colour)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3.3 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 60 station(s)
- Delayed Transmission
- Automatic redialing
Document & Media Handling
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 250 sheets
- Input tray - 250 sheets , ADF - 30 sheets
- Speed Details
- Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 15 ppm - B/W (ISO/IEC 24734) , Printing: up to 8 ppm - colour (ISO/IEC 24734) , Printing: up to 6.5 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour duplex (ISO/IEC 24734)
- 1 x USB , 1 x LAN - RJ-45
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1
- Voltage Required
- 13 Watt
- Power Consumption Sleep
- 1.5 Watt
- Consumables Included
- 2 x ink tank (black) - up to 14000 pages , 2 x ink tank (cyan) - up to 11200 pages , 2 x ink tank (magenta) - up to 11200 pages , 2 x ink tank (yellow) - up to 11200 pages
- ENERGY STAR Certified
- Limited warranty - 1 year / 50000 pages - carry-in
- 37.5 cm
- 34.7 cm
- 23.1 cm
- 4.7 kg
- Sound Emission
- 37 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £15.02 |
Epson Premium Glossy A4 Photo Paper 15 Sheets | In Stock | £12.38 |
Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) | In Stock | £12.38 |
Epson Premium Glossy Photo Paper - 30 Sheets | In Stock | £9.57 |
Epson Premium Glossy Photo Paper BOGOF - 100 x 150 mm - 255 g/m2 - 40 sheets (pack of 2 ) | In Stock | £8.79 |
Epson Ultra Glossy Photo Paper 10x15 50 Sheets | In Stock | £12.74 |
Epson A4 Glossy Photo Paper 20 Sheets | In Stock | £9.57 |
Epson Glossy Photo Paper 50 Sheets | In Stock | £8.08 |
Epson Glossy Photo Paper 50 Sheets | In Stock | £6.98 |
Epson Glossy Photo Paper 100 Sheets | In Stock | £8.76 |
Epson Glossy Photo Paper 200 Sheets | In Stock | £31.53 |
Epson A4 Glossy Photo Paper 50 Sheets | In Stock | £18.73 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.34 |
Epson 102 EcoTank Magenta Ink Bottle | In Stock | £7.10 |
Epson 102 EcoTank Yellow Ink Bottle | In Stock | £7.10 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.34 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
