Epson EcoTank ET-4550 Multifunction 4-in-1 Colour Inkjet Printer
Quicklinx: BP38WS00 Mfr#: C11CE71404BY
Say goodbye to ink cartridges
The star of the ET-4550 is its newly designed integrated ultra-high-capacity ink tank system, which completely does away with the need for ink cartridges. That means less fuss and much more printing between refills than other inkjet printers. As well as doing away with ink cartridges, the ET-4550 has six 70ml colour and two 140ml black Epson genuine ink bottles in the box, which are easy, clean and quick to use.
Ultra-low cost
The ET-4550 saves you 70% on printing costs on average. Included in the box are two full sets of ink which will enable you to print up to 11,000 pages in black and colour , at just a fraction of a penny per page . In fact, a customer would need to buy 72 ink cartridges on average to get the same yields .
Wi-Fi and Ethernet connectivity
Equipped with Wi-Fi and Wi-Fi direct, the ET-4550 can take advantage of all Epson Connect4 features. Print quickly and easily over Wi-Fi from a smartphone using the free Epson iPrint app, print remotely or email the ET-4550 a print job.
Quick, quality results
The ET-4550 uses Epson's own Micro Piezo technology for excellent-quality print-outs. Mono prints are delivered at a rate of 13 pages per minute while it can issue 7.3 colour pages per minute5. The 150-sheet paper tray, 30-page ADF and automatic duplex printing help you boost productivity, while black pigment ink is used to deliver high-quality text printing.
  • Say goodbye to cartridges
    Perfect for any small office, this 4-in-1 inkjet printer comes with enough ink to print up to 11,000 pages without the need for cartridges.
Epson EcoTank ET-4550 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 13.7 ppm (mono) / up to 7.3 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, LAN, Wi-Fi(n)
AirPrint Enabled
AC 120/230 V
51.5 cm x 36 cm x 24.1 cm
7.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
USB, LAN, Wi-Fi(n)
AirPrint Enabled
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
400 nozzles (black), 128 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.3 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Automatic redialing, colour faxing, delayed sending
Document & Media Handling
Original Type
Sheets
30 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
150 sheets
Input tray - 150 sheets , ADF - 30 sheets
Speed Details
Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 13.7 ppm - B/W (ISO/IEC 24734) , Printing: up to 7.3 ppm - colour (ISO/IEC 24734) , Printing: up to 6.5 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 4.5 ppm (A4) - colour duplex (ISO/IEC 24734)
1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
Software Included
Epson Event Manager, EPSON Scan, Epson Fax Utility, EpsonNet Config
AC 120/230 V
11 Watt
Power Consumption Sleep
1.5 Watt
Consumables Included
1 x ink tank (black) - up to 11000 pages , 1 x ink tank (cyan) - up to 11000 pages , 1 x ink tank (magenta) - up to 11000 pages , 1 x ink tank (yellow) - up to 11000 pages
ENERGY STAR Certified
51.5 cm
36 cm
24.1 cm
7.4 kg
Sound Emission
46 dBA (operating)
BP38 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
