Epson EcoTank ET-4500 Multifunction 4-in-1 Colour Inkjet Printer
Quicklinx: BP37WS00 Mfr#: C11CE90401
Functionality: Copier, Fax, Printer, Scanner
Technology: Ink-jet
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
Hurry, only 1 left in stock!
£290.40 ex VAT
£348.48 inc VAT
Say goodbye to ink cartridges
The star of the ET-4500 is its newly designed integrated ultra-high-capacity ink tank system, which completely does away with the need for ink cartridges. That means less fuss and much more printing between refills than other inkjet printers.
Two years of ink
Imagine not having to think about ink for two years. As well as doing away with ink cartridges, the ET-4500 has four colour 70ml Epson genuine ink bottles in the box, which make it easy, clean and quick to fill the ink tanks.
Ultra-low cost
The ET-4500 saves you 70% in printing costs on average. It achieves an ultra-low cost per page, printing up to 4,000 pages in black and 6,500 pages in colour at just a fraction of a penny per page4.
Wi-Fi and Ethernet connectivity
Equipped with Wi-Fi and Wi-Fi direct, the ET-4500 can take advantage of all Epson Connect5 features. Print quickly and easily over Wi-Fi from a smartphone using the free Epson iPrint app, print remotely or email the ET-4500 a print job.
Quick, quality results
The ET-4500 uses Epson's own Micro Piezo technology for excellent-quality print-outs. Mono prints are delivered at a rate of 9.2 pages per minute while it can issue 4.5 colour pages per minute. A 30-page ADF helps boost productivity.
  • Cartridge-free printing
    Great for any home office, this 4-in-1 inkjet printer can reduce ink costs by 90% on average .
Epson EcoTank ET-4500 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 33 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB, LAN, Wi-Fi
AirPrint Enabled
AC 120/230 V
49 cm x 37.7 cm x 22.9 cm
6.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
USB, LAN, Wi-Fi
AirPrint Enabled
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Automatic redialing, colour faxing, delayed sending
Document & Media Handling
Original Type
Sheets
30 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
100 sheets
Input tray - 100 sheets , ADF - 30 sheets
Speed Details
Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: up to 9.2 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - color (ISO/IEC 24734)
1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows Server 2008 R2, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 R2, MS Windows Server 2012 R2, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits)
Software Included
Epson Event Manager, EPSON Scan, Epson Fax Utility, EpsonNet Config
AC 120/230 V
11 Watt
Power Consumption Sleep
1.6 Watt
Consumables Included
1 x ink tank (black) - up to 4000 pages , 1 x ink tank (cyan) - up to 6500 pages , 1 x ink tank (magenta) - up to 6500 pages , 1 x ink tank (yellow) - up to 6500 pages
ENERGY STAR Certified
49 cm
37.7 cm
22.9 cm
6.3 kg
Sound Emission
39 dBA (operating)
Ink (6)
BP37 Epson T6641 Black Ink bottle for L Series In Stock £6.18
BP37 Epson T6642 Cyan Ink Bottle L-Series Ink Tank In Stock £6.13
BP37 Epson T6643 Magenta Ink Bottle L-Series Ink Tank In Stock £6.18
BP37 Epson T6644 Yellow Ink Bottle L-Series Ink Tank In Stock £6.18
BP37 Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £9.42
BP37 Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.42
Other bundles (3)
BP37 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
BP37 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
BP37 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.51
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Technology: Ink-jet
Brand: Epson
Price Range Ex VAT: 150 - 300
