Epson EcoTank ET-3750 Colour Inkjet 33ppm Multifunction Printer
Quicklinx: DL3RWS00 Mfr#: C11CG20401CA
Shrink your overheads with Epson's cartridge-free EcoTank, which can reduce printing costs. This 3-in-1 inkjet with Wi-Fi and Wi-Fi Direct features fast print speeds and double-sided printing.
  • Ultra-low cost
    EcoTank can slash ink costs by 90% on average thanks to its innovative design. It features an ultra-high-capacity ink tank that removes the need for cartridges. This model comes with an additional set of ink bottles.
  • Print thousands of pages
    Get more prints between refills. Thanks to the ink included in the box, it can print 14,000 pages in black and 11,200 in colour.
  • Discover the next generation of EcoTank
    With the ink tank now housed at the front, EcoTank is more compact and easier to use than ever before. Protecting you against leaks and spills, it features an enhanced ink filling system engineered for mess-free refills. The new bottles also incorporate a mechanism to ensure that only the correct colours are inserted.
  • Print from almost anywhere
    With Wi-Fi and Wi-Fi Direct, you can send documents to print from smart devices using the Epson iPrint app. It can even receive files from almost anywhere in the world via Epson Email Print.
Epson EcoTank ET-3750 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson PrecisionCore - 4-ink
Max Printing Speed
Up to 15 ppm (mono) / up to 8 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Printing Resolution Class
Scanning
1200 x 2400 dpi
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
150 sheets
Output Trays Capacity
30 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, LAN, Wi-Fi
AirPrint Enabled
AC 230 V (50/60Hz)
37.5 cm x 34.7 cm x 23.1 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
Display Colour Support
USB, LAN, Wi-Fi
AirPrint Enabled
Printing
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
400 nozzles (black), 128 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3.3 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
30 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
150 sheets
30 sheets
Input tray - 150 sheets , ADF - 30 sheets , Output tray - 30 sheets
Speed Details
Printing: up to 33 ppm - B/W , Printing: up to 20 ppm - colour , Printing: up to 15 ppm - B/W (ISO/IEC 24734) , Printing: up to 8 ppm - colour (ISO/IEC 24734) , Printing: up to 6.5 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour duplex (ISO/IEC 24734)
1 x USB , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1
AC 230 V (50/60Hz)
13 Watt
Power Consumption Sleep
1.5 Watt
Consumables Included
2 x ink tank (black) - up to 14000 pages , 2 x ink tank (cyan) - up to 11200 pages , 2 x ink tank (magenta) - up to 11200 pages , 2 x ink tank (yellow) - up to 11200 pages
ENERGY STAR Certified
Limited warranty - 1 year / 50000 pages - carry-in
37.5 cm
34.7 cm
23.1 cm
4.7 kg
Sound Emission
38 dBA (operating)
