The Epson EB-W16SK is an affordable 3D projector system for large audiences. Supplied in a specially designed mount, with polarising plates attached to each lens, two units are linked via USB cable to simultaneously project onto a silver screen, sold separately¹. This helps create bright, high-quality 3D projections every time.
The Epson EB-W16SK is the only passive 3D projector system to support all four different 3D signal formats – side-by-side, top-and-bottom, frame packing and frame sequential – ensuring that all types of content can be projected.
This projector system comes with one pair of polarised 3D glasses for bright three dimensional content. Thanks to their low production costs, these glasses offer an affordable 3D experience with low Total Cost of Ownership and are ideal for large audiences.
This 3D projector system is quick and simple to set up. Positioning the units on top of each other in the specially designed mount, users can easily align both images using the automatic projector alignment setting.
Bright, Passive 3D
Epson's easy-to-set-up passive 3D projector system delivers bright, high definition 3D content and supports all current 3D signal formats.
- Epson EB-W16SK Passive 3D Projector System - 3LCD projector - portable - 3D
- 3LCD projector
- 3D Capable
- Yes (3D glasses included)
- Built-in Devices
- Speaker
- Brightness
- 3000 lumens
- Contrast Ratio
- 5000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- E-TORL UHE 200 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50/60 Hz)
- 311 Watt
- 32.5 cm x 24.3 cm x 7.7 cm
- 2.6 kg
- 3-year warranty
- 3LCD projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 lumens
- Brightness (Reduced)
- 2400 lumens
- Contrast Ratio
- 5000:1
- Image Size
- 90 cm - 900 cm
- Projection Distance
- 1.1 m - 10.8 m
- Throw Ratio
- 1.3 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Display Format
- 1,024,000 pixels (1,280 x 800) x 3
- Max Sync Rate (V x H)
- 240 Hz
- Bulb type
- Bulb life cycle
- Auto Vertical Keystone, EPSON 3LCD technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 2 Watt
- 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 , 1 x network - RJ-45 , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input , 1 x S-video input , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Carrying case, wireless remote control, dual projector stacking mount kit, 2 x polarising filters
- Mounting Kit
- Included
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Voltage Required
- 311 Watt
- Power Consumption Operational (Standby)
- 0.47 Watt
- 32.5 cm
- 24.3 cm
- 7.7 cm
- 2.6 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- Sound Emission
- 36 dBA
- Sound Emission (Economic Mode)
- 29 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
