Epson EB-Z9870 WUXGA 8700 lumens LCD Projector - White
Quicklinx: BJKBWS00 Mfr#: V11H611040
Clear images and 3LCD technology
At 8,700 lumens the EB-Z9870U is bright and boasts a WUXGA resolution. This projector benefits from Epson's 3LCD technology, which ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors .
Perfect for large venues
Museums, auditoriums and corporate environments can benefit from the EB-Z9870U's large projected image, ideal for making a big impact.
Portrait projection
Able to project portrait aspect images, the EB-Z9870U is ideal for digital signage. Welcome to a whole new way of seeing things; portrait mode is also useful when a venue or event, such a fashion show, doesn't lend itself to landscape projection.
Easy set-up
As well as a flexible installation angle and lens shift for off-centre positioning, the EB-Z9870U includes plenty of calibration options such as edge blending, test patterns, frame interpolation and Epson's Super Resolution feature.
The EB-Z9870U includes HDBaseT, which allows up to five connections in one. Optional Wi-Fi and an SDI input are also included for extra flexibility.
Short-throw capability
Great news for auditoriums and lecture theatres; a new and exclusive LU02 short throw lens allows this projector to be positioned closer to the screen.
  • Bright installation projector
    Simple to set up, the EB-Z9870U benefits from 8,700 lumens, WUXGA resolution and 3LCD technology.
Epson EB-Z9870U - 3LCD projector
3LCD projector - 1080p
Brightness (White)
8700 lumens
Brightness (Colour)
8700 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
380 Watt
Bulb life cycle
Up to 2000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video
948 Watt
74.1 cm x 53.4 cm x 19.7 cm
26 kg
Projector
Brightness (White)
8700 lumens
Brightness (Colour)
8700 lumens
Brightness (Reduced)
6600 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
152.4 cm - 1270 cm
Projection Distance
2 m - 27.8 m
Throw Ratio
1.57 - 2.56:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Bulb type
380 Watt
Bulb life cycle
EPSON 3LCD technology, Crystal Clear Fine (C2 Fine), 16:10 aspect ratio support, DICOM Simulation Mode, Dynamic Mode, Theater Mode
Lens
Focus Type
Powered
Lens Aperture
F/1.65-2.51
Zoom Type
Powered
Zoom Factor
1.61x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Powered
Vertical Lens Shift
60% / 60%
Horizontal Lens Shift
18% / 18%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, DVI, HD-SDI
1 x USB - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input , 1 x composite video input , 1 x component video input , 1 x composite video input - BNC x 6 , 1 x S-video input - 4 pin mini-DIN , 1 x HDBaseT - RJ-45 , 1 x HD-SDI
Remote control, HDMI cable clamp
Security Features
948 Watt
Power Consumption Stand by
0.37 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
74.1 cm
53.4 cm
19.7 cm
26 kg
20 - 80%
Sound Emission
39 dB
35 dB
BJKB C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
