Epson EB-Z9800W WXGA 8300 Lumens LCD Projector - White
Quicklinx: BJKHWS00 Mfr#: V11H615040
Clear images and 3LCD technology
At 8,300 lumens the EB-Z9800W is a very bright WXGA resolution projector. This projector benefits from Epson's 3LCD technology, which ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors .
Perfect for large venues
Museums, auditoriums and corporate environments can benefit from the EB-Z9800W's large projected image, ideal for making a big impact.
Portrait projection
Able to project portrait aspect images, the EB-Z9800W is ideal for digital signage. Welcome to a whole new way of seeing things; portrait mode is also useful when a venue or event, such a fashion show, doesn't lend itself to landscape projection.
Easy set-up
As well as a flexible installation angle and lens shift for off-centre positioning, the EB-Z9800W includes plenty of calibration options such as edge blending, test patterns and Epson's Super Resolution feature.
The EB-Z9800W includes HDBaseT, which allows up to five connections in one. Optional Wi-Fi is also included for extra flexibility.
Short-throw capability
Great news for auditoriums and lecture theatres; a new and exclusive LU02 short throw lens allows this projector to be positioned closer to the screen.
  • Bright installation projector
    With 8,300 lumens and a WXGA resolution, the EB-Z9800W large venue projector is simple to set-up and benefits from 3LCD technology.
Epson EB-Z9800W - 3LCD projector
3LCD projector
Brightness (White)
8300 lumens
Brightness (Colour)
8300 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
380 Watt
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video
AC 120/230 V (50 - 60 Hz)
809 Watt
74.1 cm x 53.4 cm x 19.7 cm
25 kg
3-year warranty
3LCD projector
Projector
Brightness (White)
8300 lumens
Brightness (Colour)
8300 lumens
Brightness (Reduced)
7100 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
152 cm - 1270 cm
Projection Distance
2 m - 27.8 m
Throw Ratio
1.57 - 2.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
380 Watt
Bulb life cycle
EPSON 3LCD technology, Crystal Clear Fine (C2 Fine), 16:10 aspect ratio support, DICOM Simulation Mode, Dynamic Mode, Theater Mode
Lens
Focus Type
Powered
Lens Aperture
F/1.65-2.51
Zoom Type
Powered
Zoom Factor
1.61x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Powered
Vertical Lens Shift
60% / 60%
Horizontal Lens Shift
18% / 18%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video, DVI
1 x USB - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input , 1 x component video input , 1 x composite video input - BNC x 6 , 1 x S-video input - 4 pin mini-DIN , 1 x HDBaseT - RJ-45 , 1 x DVI-D
Remote control, HDMI cable clamp
1 x VGA cable
Security Features
809 Watt
Power Consumption Stand by
0.37 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
74.1 cm
53.4 cm
19.7 cm
25 kg
Limited warranty - 3 years / 20000 hours - carry-in , Limited warranty - lamp - 1 year / 1000 hours
20 - 80%
Sound Emission
38 dBA
35 dBA
