Epson EB-X41 E3600 ANSI Lumens XGA 3LCD Technology Projector
Quicklinx: D94DWS00 Mfr#: V11H843041
Portability: Portable
£313.97 ex VAT
£376.76 inc VAT
Bigger is better
Whether you're watching your favourite blockbusters or delivering a presentation, this projector can achieve an impressive 300-inch display. It's great quality too, with 3LCD technology that makes the display up to three times brighter than competitor products . In addition to its bright and vivid colours, the 15,000:1 contrast ratio produces defined shadows and deep blacks. From family and friends to business colleagues and clients, it's sure to get everyone's attention.
High-quality, bright images
Even in bright rooms, this powerful yet affordable XGA projector delivers exceptionally bright yet colourful images with clear details. It's all thanks to 3LCD technology, which produces an equally high White and Colour Light Output of 3,600 lumens.
Long-lasting solution
Looking for a long-term, hassle-free and affordable solution for your projection needs? With this model's long-lasting lamp light source, you could watch a film every day for 15 years .
Stress-free set up
Here's a projector that's designed with portability and quick set up in mind. The carry case makes it easy to move from room to room, and you can quickly position the image with keystone correction and access content simply with the HDMI inputs. With the optional ELPAP10 adapter, it offers Wi-Fi connectivity, allowing you to share content from a smart device using the iProjection app.
Epson EB-X41 - 3LCD projector - portable
3LCD projector
White
Built-in Devices
Speaker
Brightness (White)
3600 lumens
Brightness (Colour)
3600 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
UHE 210 Watt
Bulb life cycle
Up to 6000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified Projectors 2
AC 120/230 V (50 - 60 Hz)
282 Watt
30.2 cm x 23.7 cm x 8.2 cm
2.5 kg
3LCD projector
Built-in Devices
Speaker
Enclosure Colour
White
Projector
Brightness (White)
3600 lumens
Brightness (Colour)
3600 lumens
Brightness (Reduced)
2235 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1.8 m - 2.17 m
Throw Ratio
1.48 - 1.77:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz
Bulb type
UHE 210 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.49-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio line-in - RCA x 2
Carrying case, wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
TCO Certified
Power Source
AC
Nominal Voltage
282 Watt
Power Consumption Stand by
0.2 Watt
30.2 cm
23.7 cm
8.2 cm
2.5 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
Brand: Epson
Price Range Ex VAT: 300 - 500
