Epson EB-W29 WXGA 3000 Lumens Projector
Quicklinx: B9RTWS00 Mfr#: V11H690041
The EB-W29 uses 3LCD technology and an equally high White and Colour Light Output to deliver exceptional image quality and accurate colours. A 10,000:1 contrast ratio produces clearer image detail.
Epson understands that being in control is important when presenting in a corporate or education environment. The EB-W29 comes with multi-PC projection software, which allows content from up to four devices, including PCs, tablets and smartphones, to be displayed simultaneously. The moderator function allows the host, whether it is the teacher, lecturer or leader of the meeting, to take control of displayed content from the devices.
Set up is easy and flexible with horizontal and vertical keystone correction, helping you achieve a perfectly shaped image without distortion. This means projectors can be quickly moved and set up in different classrooms and meeting rooms.
This projector has enhanced connectivity, giving choice and flexibility however you intend to present. The EB-W29 can connect to the latest digital devices or legacy analogue products, meaning older hardware doesn't necessarily need to be replaced. Connecting smart devices couldn't be easier with the iProjection QR code connectivity - simply scan a projected QR code using your smart device to connect and start working.
  • Portable 3LCD projector
    Small and light enough to be moved and used across several rooms, this high-quality projector produces clear bright images and comes with a range of easy-to-use features.
Epson EB-W29 - 3LCD projector - portable - LAN
3LCD projector - 720p
Built-in Devices
Speaker, 0.59-inch TFT LCD
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video, component video LAN
Speakers
Speaker(s) - integrated
270 Watt
29.7 cm x 24.4 cm x 8.7 cm
2.6 kg
3-year warranty
Built-in Devices
Ethernet
Projector
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Brightness (Reduced)
2100 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
84 cm - 813 cm
Throw Ratio
1.30 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb life cycle
sRGB colour profile, Blackboard Mode, Micro Lens Array (MLA) Technology, EPSON 3LCD technology, Whiteboard Mode, Split Screen, 16:10 aspect ratio support, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode, MHL compliance
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
5 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x VGA input , 1 x HDMI input , 1 x composite video input , 1 x component video input , 1 x S-video input - 4 pin mini-DIN , 2 x RGB input , 1 x network - RJ-45 , 2 x VGA output , 1 x serial RS-232
Carrying case, remote control
1 x VGA cable , 1 x USB cable
Security Features
Nominal Voltage
270 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
29.7 cm
24.4 cm
8.7 cm
2.6 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
29 dBA
