15 years worth of entertainment
With a long lamp and filter life, even if using the projector to watch a movie every day, it would be up to 15 years before either would need to be changed .
High-quality, bright images
Experience exceptional-quality images that are three times brighter than competitor products thanks to 3LCD technology and equally high White and Colour Light Output. View your content like never before and pick out even the finest detail with crisp, clear blacks creating clearly defined shadows, all thanks to a 15,000:1 contrast ratio.
The big picture
Able to take content from a range of sources and display it up to a massive 300 inches, the EB-W04 uses an HDMI inputs to allow users to broadcast high-quality digital video and audio content. You can even project photos and documents straight from a smartphone or tablet with Epson's iProjection app .
Everything included for fuss-free installation
An included carry case makes for easy movement of the projector from room to room. Horizontal and vertical keystone correction mean the projector can be installed in a number of places without distorting the image.
Eco-friendly features
By varying the lamp power according to what content is being displayed, the EB-W04 can help save energy, while eco-mode helps reduce power consumption and extend lamp life.
Versatile projector
High-quality, mobile projector for the home and office with 3LCD technology, WXGA resolution and flexible, easy-to-use features.
- Epson EB-W04 - 3LCD projector - portable
- 3LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness (White)
- 3000 lumens
- Brightness (Colour)
- 3000 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 200 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 277 Watt
- 29.7 cm x 23.4 cm x 7.7 cm
- 2.4 kg
- 2-year warranty
- Built-in Devices
- Speaker
Projector
- 3000 lumens
- 3000 lumens
- Brightness (Reduced)
- 2100 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 84 cm - 813 cm
- Projection Distance
- 1.68 m - 2.02 m
- Throw Ratio
- 1.3 - 1.56:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz
- Bulb type
- 200 Watt
- Bulb life cycle
- Auto Vertical Keystone, EPSON 3LCD technology, Dynamic Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.72
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2
- Included Accessories
- Carrying case, wireless remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Power Source
- AC
- Voltage Required
- 277 Watt
- Power Consumption Stand by
- 0.26 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 29.7 cm
- 23.4 cm
- 7.7 cm
- 2.4 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
