Bright, vivid content on a large scalable screen
Enjoy large scale presentations with crisp, clear text, as well as compelling imagery and video content, on screen sizes up to 350 inches. 3,300-lumen performance combines with a high contrast ratio of 15,000:1 to offer outstanding visual performance, even in well-lit rooms.
Years of uninterrupted meetings
With a lamp life and air filter maintenance cycle of 10,000 hours in eco mode, users won't need to worry about maintenance for up to 5 years1.
Installation and placement flexibility
Automatic vertical and manual horizontal keystone correction provide greater flexibility as to where the projector can be placed in the room for distortion-free images and the wide optical zoom adds to the flexibility.
Wi-Fi capability
Wi-Fi compatibility means the EB-S39 can be upgraded for wireless device access at a later stage (optional accessory required).
High quality sound
This projector has a built-in 5W speaker to allow audio content to be heard clearly without the need for seaparate external speakers.
Reliable business projector
With the versatility to mount just about anywhere, bright, sharp images and low maintenance, the EB-S39 is a great all-rounder for business.
- Epson EB-S39 - 3LCD projector - portable - grey, white
- 3LCD projector
- Grey, white
- Built-in Devices
- Speaker
- Brightness (White)
- 3300 lumens
- Brightness (Colour)
- 3300 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- UHE 210 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 309 Watt
- 30.2 cm x 24.9 cm x 9.2 cm
- 2.7 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Enclosure Colour
- Grey, white
Projector
- 3300 lumens
- 3300 lumens
- Brightness (Reduced)
- 2050 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 76 cm - 889 cm
- Throw Ratio
- 1.45 - 1.96:1
- Digital Zoom Factor
- 1.35x
- Resolution
- SVGA - SVGA (800 x 600)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz
- Bulb type
- UHE 210 Watt
- Bulb life cycle
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.44
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x HDMI - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 309 Watt
- Power Consumption Stand by
- 0.2 Watt
- Software Included
- EasyMP Network Projection, EasyMP Multi PC Projection
- 30.2 cm
- 24.9 cm
- 9.2 cm
- 2.7 kg
- Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £96.86 |
