The EB-S27 uses 3LCD technology and an equally high White and Colour Light Output to deliver exceptional image quality and accurate colours. A 10,000:1 contrast ratio produces clearer image detail.
Epson understands that being in control is important when presenting in a corporate or education environment. The EB-S27 comes with multi-PC projection software, which allows content from up to four devices, including PCs, tablets and smartphones, to be displayed simultaneously. The moderator function allows the host, whether it is the teacher, lecturer or leader of the meeting, to take control of displayed content from the devices.
Set up is easy and flexible with horizontal and vertical keystone correction, helping you achieve a perfectly shaped image without distortion. This means projectors can be quickly moved and set up in different classrooms and meeting rooms.
This projector has enhanced connectivity, giving choice and flexibility however you intend to present. The EB-S27 can connect to the latest digital devices or legacy analogue products, meaning older hardware doesn't necessarily need to be replaced. Connecting smart devices couldn't be easier with the iProjection QR code connectivity - simply scan a projected QR code using your smart device to connect and start working.
Portable 3LCD projector
Small and light enough to be moved and used across several rooms, this high-quality projector produces clear bright images and comes with a range of easy-to-use features.
- Epson EB-S27 - 3LCD projector - portable
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness (White)
- 2700 lumens
- Brightness (Colour)
- 2700 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- SVGA (800 x 600)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 273 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 273 Watt
- 29.7 cm x 24.4 cm x 8.7 cm
- 2.5 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
Projector
- 2700 lumens
- 2700 lumens
- Brightness (Reduced)
- 1890 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 76 cm - 889 cm
- Throw Ratio
- 1.45 - 1.96:1
- Digital Zoom Factor
- 1.35x
- Resolution
- SVGA - SVGA (800 x 600)
- 4:3
- Colour Support
- Bulb type
- 273 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.44
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C
- Included Accessories
- Carrying case, remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 273 Watt
- Power Consumption Stand by
- 0.26 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 29.7 cm
- 24.4 cm
- 8.7 cm
- 2.5 kg
- Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 29 dBA
