Affordable laser performance
The EB-L400U offers impressive 4,500-lumen brightness and WUXGA Full HD resolution at an affordable price, meaning you can upgrade to laser performance and reliability without paying a premium. Pin-sharp image quality and equally high White and Colour Light Output give your presentations impact, even in brightly-lit rooms.
Reliable and durable
The EB-L400U is based around Epson's proven laser technology, which offers fit and forget reliability to keep maintenance to a minimum. The projector is covered by a five-year, 12,000-hour guarantee.
Easy, flexible installation
A smaller, lighter casing than products of similar brightness makes it easy to replace existing units with the EB-L400U, while laser technology means these projectors can be mounted at and project from any angle, making them ideal for any scenario.
Stylish new design
A fresh, new casing design means that the EB-L400U will look completely at home in even the most style-conscious of new developments.
WUXGA laser projector
Affordable entry-level 4,500-lumen laser projector with sharp WUXGA resolution, ideal for replacing existing lamp-based units.
- Epson EB-L400U - 3LCD projector - LAN - white
- 3LCD projector - 1080p
- White
- Built-in Devices
- Speaker
- Brightness (White)
- 4500 lumens
- Brightness (Colour)
- 4500 lumens
- Contrast Ratio
- 2500000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- Laser
- Bulb life cycle
- Up to 20000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
- Video Input
- RGB LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 310 Watt
- 44 cm x 30.4 cm x 12 cm
- 7.8 kg
- 5-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- White
Projector
- 4500 lumens
- 4500 lumens
- Brightness (Reduced)
- 3150 lumens
- Contrast Ratio
- Image Size
- 127 cm - 1270 cm
- Projection Distance
- 1.44 m - 23.84 m
- Throw Ratio
- 1.35 - 2.2:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 240 Hz
- Bulb type
- Laser
- Bulb life cycle
- sRGB colour profile, EPSON Quick Corner, JPEG photo playback, 3LCD Technology, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Control4 Certified, Dynamic Mode, full 10-bit image processing, auto power on, Extron Control System, AMX Control System, document camera compatible, Presentation Mode, Cinema Mode, RGB liquid crystal shutter
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.5 -1.7
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x VGA input , 1 x VGA output , 2 x HDMI input , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-in - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- 310 Watt
- Power Consumption Stand by
- 0.3 Watt
- Software Included
- Epson Projector Management Software
- 44 cm
- 30.4 cm
- 12 cm
- 7.8 kg
- Limited warranty - 5 years / 12000 hours
- 20 - 80%
- Sound Emission
- 29 dBA
- Sound Emission (Economic Mode)
- 22 dBA
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £96.86 |
