Epson EB-L400U WUXGA 3LCD 4500 Lumens Projector
Quicklinx: FB5VWS00 Mfr#: V11H907041
Affordable laser performance
The EB-L400U offers impressive 4,500-lumen brightness and WUXGA Full HD resolution at an affordable price, meaning you can upgrade to laser performance and reliability without paying a premium. Pin-sharp image quality and equally high White and Colour Light Output give your presentations impact, even in brightly-lit rooms.
Reliable and durable
The EB-L400U is based around Epson's proven laser technology, which offers fit and forget reliability to keep maintenance to a minimum. The projector is covered by a five-year, 12,000-hour guarantee.
Easy, flexible installation
A smaller, lighter casing than products of similar brightness makes it easy to replace existing units with the EB-L400U, while laser technology means these projectors can be mounted at and project from any angle, making them ideal for any scenario.
Stylish new design
A fresh, new casing design means that the EB-L400U will look completely at home in even the most style-conscious of new developments.
  • WUXGA laser projector
    Affordable entry-level 4,500-lumen laser projector with sharp WUXGA resolution, ideal for replacing existing lamp-based units.
Epson EB-L400U - 3LCD projector - LAN - white
3LCD projector - 1080p
White
Built-in Devices
Speaker
Brightness (White)
4500 lumens
Brightness (Colour)
4500 lumens
Contrast Ratio
2500000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
Laser
Bulb life cycle
Up to 20000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
Video Input
RGB LAN
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
310 Watt
44 cm x 30.4 cm x 12 cm
7.8 kg
5-year warranty
Built-in Devices
Speaker
Ethernet
Enclosure Colour
White
Projector
Brightness (White)
4500 lumens
Brightness (Colour)
4500 lumens
Brightness (Reduced)
3150 lumens
Contrast Ratio
2500000:1 (dynamic)
Image Size
127 cm - 1270 cm
Projection Distance
1.44 m - 23.84 m
Throw Ratio
1.35 - 2.2:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
240 Hz
Bulb type
Laser
Bulb life cycle
sRGB colour profile, EPSON Quick Corner, JPEG photo playback, 3LCD Technology, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Control4 Certified, Dynamic Mode, full 10-bit image processing, auto power on, Extron Control System, AMX Control System, document camera compatible, Presentation Mode, Cinema Mode, RGB liquid crystal shutter
Lens
Focus Type
Manual
Lens Aperture
F/1.5 -1.7
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x VGA input , 1 x VGA output , 2 x HDMI input , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-in - mini-phone stereo 3.5 mm
Wireless remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
Power Source
AC
310 Watt
Power Consumption Stand by
0.3 Watt
Software Included
Epson Projector Management Software
44 cm
30.4 cm
12 cm
7.8 kg
Limited warranty - 5 years / 12000 hours
20 - 80%
Sound Emission
29 dBA
22 dBA
FB5V Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) In Stock £101.71
FB5V Epson Wireless Adaptor LAN B/G/N In Stock £101.99
