Epson EB-G7900U-WUXGA 7000 ANSI Lumens Installation
Quicklinx: C9MQWS00 Mfr#: V11H749041
Portability: Non-portable
Hurry, only 3 left in stock!
£3,214.60 ex VAT
£3,857.52 inc VAT
Superior image quality
Ensure superb quality and the best possible delivery of presentations with this powerful installation projector for large venues. Featuring Epson's own 3LCD technology and equally high White and Colour Light Output, WUXGA resolution images are vivid and bright, even in daylight with its 7,000 lumens brightness. For a next-level viewing experience, the projector features 4K enhancement, giving images exceptional sharpness, clarity and detail.
Easy positioning
Thanks to a new range of motorised lenses, including optional ultra-short throw (UST) lens, and both vertical and horizontal lens shift, the projector benefits from true 360° installation flexibility allowing it to be placed almost anywhere.
Quick set-up
Get started quickly thanks to a lens memory function, which stores projector settings such as image position, focus and zoom, for prompt access when projecting images in different aspect ratios, or using different lenses. Split-screen allows dual feeds to be projected, while a portrait projection mode is possible without changing the lamp. For integration with a wide range of systems, inputs include HDMI, HDBaseT, DVI-D and component video.
  • WUXGA installation projector
    Easy to set-up and with low maintenance requirements, this 7,000-lumens WUXGA installation projector boasts bright images, vivid colours and 4K-enhanced detail.
Epson EB-G7900U - 3LCD projector - LAN
3LCD projector - 1080p
Built-in Devices
Speaker
Brightness (White)
7000 lumens
Brightness (Colour)
7000 lumens
Contrast Ratio
2000:1 / 50000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens Shift Direction
Horizontal, vertical
Bulb type
400 Watt
Bulb life cycle
Up to 2000 hours - normal mode , Up to 4000 hours - economic mode
Video Input
RGB, component video LAN
Speakers
Speaker(s) - integrated
572 Watt
52.5 cm x 47.2 cm x 18.9 cm
12.7 kg
Built-in Devices
Speaker
Ethernet
Projector
Brightness (White)
7000 lumens
Brightness (Colour)
7000 lumens
Brightness (Reduced)
5600 lumens
Contrast Ratio
Image Size
127 cm - 762 cm
Projection Distance
1.5 m - 15.1 m
Throw Ratio
1.44 - 2.33:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Bulb type
400 Watt
Bulb life cycle
sRGB colour profile, EPSON 3LCD technology, DICOM Simulation Mode, Dynamic Mode
Lens
Focus Type
Powered
Lens Aperture
F/1.7-2.3
Zoom Type
Powered
Zoom Factor
1.6x
Keystone Correction Direction
Vertical Keystone Correction
-45 / +45
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Powered
Vertical Lens Shift
67% / 67%
Horizontal Lens Shift
30% / 30%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, DVI
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x HDBaseT , 1 x component video input - BNC x 5 , 1 x audio line-out - mini-phone stereo 3.5 mm , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management)
Cable cover, remote control
1 x VGA cable
Security Features
Power Source
AC
Nominal Voltage
572 Watt
Power Consumption Stand by
0.5 Watt
52.5 cm
47.2 cm
18.9 cm
12.7 kg
20 - 80%
Sound Emission
39 dB
31 dB
C9MQ C2G 2m USB 2.0 A/B Cable - Black In Stock £3.72
C9MQ C2G 5m USB 2.0 A/B Cable - Black In Stock £4.94
C9MQ C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.13
Brand: Epson
Price Range Ex VAT: 1500+
