Epson EB-G6050W WXGA 3LCD 5500 Lumens Projector
Quicklinx: 96Q0WS00 Mfr#: V11H511041
The Epson EB-G6050W boasts superior picture quality, ensuring the best possible projection for important presentations. The Colour Uniformity function compensates for unequal colour distribution by adjusting the intensity of RGB on individual areas of the screen.
New and innovative features are designed to offer the best possible presenting tools. The projector can be rotated vertically by 360 degrees so the projection image can be easily moved around the room.
The Epson EB-G6050W is easy to set up and use, thanks to a variety of user-friendly installation features. Pixel alignment, for example, enables the user to align pictures easily and effectively during set up for clear, correct images. With edge blending, a large, widescreen image can be projected from a number of projectors working together seamlessly. Its powerful zoom lens, as well as manual vertical keystone correction and centred lens, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
With the HDMI input, a variety of high definition devices can be connected to deliver HD-Ready content effortlessly.
For simpler integration, this model is also compatible with the Epson EB-G5 series lenses .
  • HD-Ready business projector
    Powerful 5,500-lumen EB-G6050W professional installation projector with WXGA screen resolution to deliver sharper, clearer presentations.
Epson EB-G6050W - 3LCD projector - LAN
3LCD projector
Built-in Devices
Speaker
Brightness
5500 lumens
Brightness (Colour)
5500 lumens
Contrast Ratio
5000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
380 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video LAN
Speakers
Speaker(s) - integrated
477 Watt
50.5 cm x 40.6 cm x 14.4 cm
9.7 kg
3-year warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
5500 lumens
Contrast Ratio
5000:1
Image Size
127 cm - 762 cm
Projection Distance
1.4 m - 15 m
Throw Ratio
1.26 - 2.3:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
380 Watt
Bulb life cycle
sRGB colour profile, instant shutdown, EPSON 3LCD technology, EPSON Cinema Filter, Crystal Clear Fine (C2 Fine), DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.65-2.55
Zoom Factor
1.8x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Manual
Vertical Lens Shift
67% / 67%
Horizontal Lens Shift
30% / 30%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, component video, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 4 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x component video input - BNC x 5 , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x audio line-in - RCA x 2
HDMI cable clamp
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), security bar
477 Watt
Power Consumption Stand by
0.41 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
50.5 cm
40.6 cm
14.4 cm
9.7 kg
Limited warranty - 3 years / 15000 hours - carry-in , Limited warranty - lamp - 3 years / 3000 hours
20 - 80%
Sound Emission
37 dBA
31 dBA
96Q0 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
