Product
Epson EB-965H XGA 3500 Lumens Projector
Quicklinx: B9W6WS00 Mfr#: V11H682041
The EB-965H uses 3LCD technology and an equally high White and Colour Light Output to deliver exceptional image quality and accurate colours. A 10,000:1 contrast ratio produces clearer image detail.
Epson understands that being in control is important when presenting in a corporate or education environment. The EB-965H comes with multi-PC projection software, which allows content from up to four devices, including PCs, tablets and smartphones, to be displayed simultaneously. The moderator function allows the host, whether it is the teacher, lecturer or leader of the meeting, to take control of displayed content from the devices.
Set up is easy and flexible with horizontal and vertical keystone correction, helping you achieve a perfectly shaped image without distortion. This means projectors can be quickly moved and set up in different classrooms and meeting rooms.
This projector has enhanced connectivity, giving choice and flexibility however you intend to present. The EB-965H can connect to the latest digital devices or legacy analogue products, meaning older hardware doesn't necessarily need to be replaced. Connecting smart devices couldn't be easier with the iProjection QR code connectivity - simply scan a projected QR code using your smart device to connect and start working.
  • Portable 3LCD projector
    Small and light enough to be moved and used across several rooms, this high-quality projector produces clear bright images and comes with a range of easy-to-use features.
Epson EB-965H - 3LCD projector - portable - LAN
3LCD projector
Built-in Devices
Speaker
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
215 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video LAN
Speakers
Speaker(s) - integrated
287 Watt
29.7 cm x 26.9 cm x 8.7 cm
2.9 kg
3 years warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Brightness (Reduced)
2450 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
76 cm - 762 cm
Throw Ratio
1.38 - 2.24:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz
Bulb type
215 Watt
Bulb life cycle
EPSON 3LCD technology, MHL compliance
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x audio line-in - RCA x 2
Carrying case, remote control
287 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
29.7 cm
26.9 cm
8.7 cm
2.9 kg
Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
29 dBA
B9W6 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B9W6 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.38
B9W6 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.34
B9W6 C2G 10m Select High Speed HDMI with Ethernet In Stock £40.97
B9W6 C2G 15m Select High Speed HDMI with Ethernet In Stock £55.48
B9W6 C2G Pro HDMI to VGA Converter In Stock £51.15
B9W6 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
