Epson EB-955WH WXGA 3200 Lumens Projector
Quicklinx: B9W5WS00 Mfr#: V11H683041
The EB-955WH uses 3LCD technology and an equally high White and Colour Light Output to deliver exceptional image quality and accurate colours. A 10,000:1 contrast ratio produces clearer image detail.
Epson understands that being in control is important when presenting in a corporate or education environment. The EB-955WH comes with multi-PC projection software, which allows content from up to four devices, including PCs, tablets and smartphones, to be displayed simultaneously. The moderator function allows the host, whether it is the teacher, lecturer or leader of the meeting, to take control of displayed content from the devices.
Set up is easy and flexible with horizontal and vertical keystone correction, helping you achieve a perfectly shaped image without distortion. This means projectors can be quickly moved and set up in different classrooms and meeting rooms.
This projector has enhanced connectivity, giving choice and flexibility however you intend to present. The EB-955WH can connect to the latest digital devices or legacy analogue products, meaning older hardware doesn't necessarily need to be replaced. Connecting smart devices couldn't be easier with the iProjection QR code connectivity - simply scan a projected QR code using your smart device to connect and start working.
  • Portable 3LCD projector
    Small and light enough to be moved and used across several rooms, this high-quality projector produces clear bright images and comes with a range of easy-to-use features.
Epson EB-955WH - 3LCD projector - portable - LAN
3LCD projector - 720p
Built-in Devices
Speaker, 0.59-inch TFT LCD
Brightness (White)
3200 lumens
Brightness (Colour)
3200 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
215 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video LAN
Speakers
Speaker(s) - integrated
287 Watt
29.7 cm x 26.9 cm x 8.7 cm
2.9 kg
3-year warranty
Built-in Devices
Ethernet
Projector
Brightness (White)
3200 lumens
Brightness (Colour)
3200 lumens
Brightness (Reduced)
2240 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
83 cm - 711 cm
Projection Distance
1.79 m - 2.92 m
Throw Ratio
1.38 - 2.24:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
215 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, Direct Power On, Direct Power Off, Dynamic Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x audio line-in - RCA x 2 , 1 x microphone
Carrying case, remote control
Power Source
AC
287 Watt
Power Consumption Stand by
0.26 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
29.7 cm
26.9 cm
8.7 cm
2.9 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
29 dBA
B9W5 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
