Epson EB-695Wi 3500 Lumens WXGA UST Projector
Quicklinx: CVX0WS00 Mfr#: V11H740041
Portability: Non-portable
18 in stock
£2,077.53 ex VAT
£2,493.03 inc VAT
With a brightness of 3,500 lumens and HD-readyWXGA resolution, the EB-695Wi's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. This projector offers ultimate interactivity by combining finger-touch with dual pen capability. A 14,000:1 contrast ratio and HDMI input mean that students benefit from sharp, clear images.
High brightness and image quality
Epson’s 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors1. With a scalable display size of up to 100 inches, two types of content can be displayed using the split-screen without compromising on quality.
Finger-touch and dual pen
Use your fingers to annotate directly onto the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, teacher and student or two students can work simultaneously using different attributes
Highly reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
Interact and enhance learning
Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what content to display. Combine two projectors to create one large interactive display. Split-screen capability allows teachers to display two separate types of content simultaneously, such as a lesson plan from a PC and a still image or video clip from a document camera.
Optional wireless capability
Wirelessly display content easily from a range of smart devices and Google Chromebooks using our iProjection App**
Projection System
3LCD Technology
LCD Panel
0.59 inch with D9
Colour Light Output
3,500 Lumen- 2,900 Lumen (economy) In accordance with IDMS15.4
White Light Output
3,500 Lumen - 2,900 Lumen (economy) In accordance with ISO 21118:2012
Resolution
WXGA, 1280 x 800, 16:10
High Definition
HD ready
Aspect Ratio
16:10
Contrast Ratio
14,000 : 1
Lamp
250 W, 5,000 h durability, 10,000 h durability (economy mode), 9,000 h durability (economy mode
Keystone Correction
Manual vertical: ± 3 °, Manual horizontal ± 3 °
Colour Processing
10 Bits
2D Vertical Refresh Rate
100 Hz - 120 Hz
Colour Reproduction
Upto 1.07 billion colours
Projection Ratio
0.28 - 0.37:1
Zoom
Digital, Factor: 1 - 1.35
Lens
Optical
Image Size
60 inches - 100 inches
Projection Distance Wide
0.4 m ( 60 inch screen)
Projection Distance Tele
0.6 m ( 100 inch screen)
Projection Lens F Number
1.6
Focal Distance
3.7 mm
Focus
Manual
Offset
5.8 : 1
USB Display Function
USB 2.0 Type A, USB 2.0 Type B, RS-232C, Wired Network, Wireless LAN IEEE 802.11b/g/n (optional), VGA in (2x), VGA out, HDMI in (3x), Composite in, RGB in (2x), RGB out, MHL, Stereo mini jack audio out, Stereo mini jack audio in (3x), Microphone input, Sync. in, Sync. out
Epson iProjection App
Ad-Hoc / Infrastructure
2D Colour Modes
Dynamic, Cinema, Presentation, sRGB, Blackboard
Interactivity
Yes - pen and finger-touch
Video Colour Modes
Blackboard, Cinema, Dynamic, Presentation, sRGB
Projector control
via: AMX, Crestron, Control4
Energy Use
354 Watt, 309 Watt (economy), 0.37 Watt (standby)
Supply Voltage
AC 220 V - 240 V, 50 Hz - 60 Hz
Product dimensions
367? x 400 x 149 mm (Width x Depth x Height)
Product weight
5.8 kg
Noise Level
Normal: 35 dB (A) - Economy: 30 dB (A) - Eco2: 29 dB (A)
Temperature
Operation 5° C - 40° C, Storage -10° C - 60° C
Humidity
Operation 20% - 80%, Storage 10% - 90%
Included Software
Easy Interactive Tools, EasyMP Network Monitor, EasyMP Multi PC Projection
Options
Air filter, Connection and control box, Document camera, External Speaker, Pen tip(Felt), Pen tip(Teflon), Wireless LAN unit
Compatible Operating Systems
Linux, Mac OS 10.10.x, Mac OS 10.7.x, Mac OS 10.8.x, Mac OS 10.9.x, Windows 10, Windows 8, Windows 8.1
Loudspeaker
16 Watt
What's in the box
CD Manual, Finger touch unit, Interactive pens, Main unit, Pen tray, Power cable, Quick Start Guide, Remote control incl. batteries, SMART Notebook software entitlement booklet, USB cable, User Manual (CD-ROM), Wall hanging bracket, Warranty card
White / Grey
Warranty
36 months On-site service or 8,000 h, Lamp: 12 months or 1,000 h
Projection System
3LCD Technology
LCD Panel
0.59 inch with D9
Colour Light Output
White Light Output
Resolution
High Definition
HD ready
Aspect Ratio
16:10
Contrast Ratio
14,000 : 1
Lamp
Keystone Correction
Colour Processing
10 Bits
100 Hz - 120 Hz
Colour Reproduction
Projection Ratio
0.28 - 0.37:1
Zoom
Lens
Optical
Image Size
1.6
Focal Distance
3.7 mm
Focus
Manual
Offset
5.8 : 1
2D Colour Modes
Interactivity
Video Colour Modes
Projector control
Energy Use
Supply Voltage
Product dimensions
Product weight
5.8 kg
Noise Level
Temperature
Humidity
Included Software
Options
Loudspeaker
16 Watt
What's in the box
White / Grey
Warranty
Brand: Epson
Price Range Ex VAT: 1500+
