Epson EB-685Wi 3500 Lumens WXGA UST Ultra Short Throw Projector
Quicklinx: CVY5WS00 Mfr#: V11H741041
This projector offers superb interactivity thanks to its dual pen capability. With a brightness of 3,500 lumens and HD-ready WXGA resolution, the EB-685Wi's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. A 14,000:1 contrast ratio and HDMI input mean that students benefit from sharp, clear images.
High brightness and image quality
Epson’s 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors1. With a scalable display size of up to 100 inches, two types of content can be displayed using the split-screen without compromising on quality.
Dual pen
Epson's interactive pens are now even more responsive and easy to use when annotating directly on screen. With the new dual pens, teacher and student or two students can work simultaneously using different attributes.
Highly reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
Interact and enhance learning
Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what content to display. Combine two projectors to create one large interactive display. Split-screen capability allows teachers to display two separate types of content simultaneously, such as a lesson plan from a PC and a still image or video clip from a document camera.
Optional wireless capability
Wirelessly display content easily from a range of smart devices and Google Chromebooks using our iProjection App.
  • HD-ready pen-interactive projector
    Innovative pen-interactive teaching solution with a large scalable screen of up to 100 inches, designed to enhance collaborative learning.
Epson EB-685Wi - 3LCD projector - LAN - grey, white
3LCD projector - 720p
Grey, white
Built-in Devices
Speaker
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Contrast Ratio
300:1 / 14000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
250 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video LAN
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified Projectors 8
AC 230V (50 - 60 Hz)
354 Watt
36.7 cm x 40 cm x 14.9 cm
5.9 kg
3-year warranty
Built-in Devices
Speaker
Ethernet
Enclosure Colour
Grey, white
Projector
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Brightness (Reduced)
2900 lumens
Contrast Ratio
Image Size
152 cm - 254 cm
Projection Distance
0.4 m - 0.6 m
Throw Ratio
0.28:1
Digital Zoom Factor
1.35x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
250 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out
Wall mounting kit, pen tray, wireless remote control, interactive pens
1 x USB cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection
TCO Certified
Power Source
AC
354 Watt
Power Consumption Stand by
0.39 Watt
Software Included
Epson Easy Interactive Tools, EasyMP Monitor, EasyMP Multi PC Projection
36.7 cm
40 cm
14.9 cm
5.9 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
35 dBA
30 dBA
CVY5 Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) In Stock £101.71
CVY5 Epson Wireless Adaptor LAN B/G/N In Stock £101.99
CVY5 Epson ELPDC07 Digital Document Camera In Stock £180.47
