The EB-685W's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. With a brightness level of 3,500 lumens, an HD-ready WXGA resolution, a 14,000:1 contrast ratio, and HDMI input, students benefit from sharp, clear images.
High-quality, bright images
Epson's 3LCD technology ensures high-quality images with equally high white and color light output for vivid colors and bright images, even in daylight, and three times brighter colors than leading competitive projectors. -
Keep costs down
Project for longer with improved reliability and a longer lamp life in Eco mode. -
Enhanced learning
Split-screen functionality allows two pieces of content to be displayed simultaneously without compromising on quality. The moderator function allows teachers to remain in control, choosing what content to display.
- Epson EB-685W - 3LCD projector - LAN - grey, white
- 3LCD projector - 720p
- Grey, white
- Built-in Devices
- Speaker
- Brightness (White)
- 3500 lumens
- Brightness (Colour)
- 3500 lumens
- Contrast Ratio
- 300:1 / 14000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 250 Watt
- Video Input
- RGB, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 354 Watt
- 36.7 cm x 40 cm x 14.9 cm
- 5.7 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- Grey, white
Projector
- 3500 lumens
- 3500 lumens
- Brightness (Reduced)
- 2900 lumens
- Contrast Ratio
- Image Size
- 152 cm - 254 cm
- Projection Distance
- 0.4 m - 0.6 m
- Throw Ratio
- 0.28:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Bulb type
- 250 Watt
- sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x USB cable
- Mounting Kit
- Included
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Power Source
- AC
- Voltage Required
- 354 Watt
- Power Consumption Stand by
- 0.39 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 36.7 cm
- 40 cm
- 14.9 cm
- 5.7 kg
- Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 30 dBA
Epson ELPMB23 Projector Mount | In Stock | £109.44 |
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £99.99 |
Epson Wireless Adaptor LAN B/G/N | In Stock | £98.83 |
Epson ELPDC07 Digital Document Camera | In Stock | £180.47 |
