Epson EB-680 XGA 3LCD 3500 Lumens Projector
Quicklinx: FB5CWS00 Mfr#: V11H746041
Portability: Non-portable
£1,175.81 ex VAT
£1,410.97 inc VAT
With a brightness of 3,500 lumens and XGA resolution, the EB-680's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. A 14,000:1 contrast ratio and HDMI input mean that students benefit from sharp, clear images.
  • High-quality, bright images
    Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors.
  • Keep costs down
    Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
  • Enhanced learning
    Split-screen functionality allows two pieces of content to be displayed simultaneously without compromising on quality. The moderator function allows teachers to remain in control, choosing what content to display.
  • Optional wireless capability
    Wirelessly display content easily from a range of smart devices and Google Chromebooks using our iProjection App.
  • Document camera compatibility
    Connecting the optional Epson document camera allows you to easily display images and 3D objects with incredible detail for the whole class to see.
Epson EB-680 - 3LCD projector - LAN - grey, white
3LCD projector
Grey, white
Built-in Devices
Speaker
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Contrast Ratio
300:1 / 14000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
250 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
354 Watt
36.7 cm x 40 cm x 14.9 cm
5.7 kg
3-year warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Enclosure Colour
Grey, white
Projector
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Brightness (Reduced)
2800 lumens
Contrast Ratio
Image Size
142 cm - 236 cm
Projection Distance
0.4 m - 0.6 m
Throw Ratio
0.32:1
Digital Zoom Factor
1.35x
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Bulb type
250 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15)
Wireless remote control
1 x USB cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
354 Watt
Power Consumption Stand by
0.39 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
36.7 cm
40 cm
14.9 cm
5.7 kg
Limited warranty - 3 years / 8000 hours - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
35 dBA
28 dBA
FB5C Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) In Stock £101.71
FB5C Epson ELPDC07 Digital Document Camera In Stock £180.47
Brand: Epson
Price Range Ex VAT: £1000 - £1500
