Epson EB-675Wi 3200 Lumens WXGA UST Ultra Short Throw Projector
Quicklinx: CVY4WS00 Mfr#: V11H743041
This projector offers superb interactivity thanks to its dual pen capability. With a brightness level of 3,200 lumens and HD-ready WXGA resolution, the EB-675Wi's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. A 14,000:1 contrast ratio and HDMI input mean that students benefit from sharp, clear images.
High brightness and image quality
Epson’s 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors1. With a scalable display size of up to 100 inches, two types of content can be displayed using the split-screen without compromising on quality.
Dual pen
Epson's interactive pens are now even more responsive and easy to use when annotating directly on screen. With the new dual pens, teacher and student or two students can work simultaneously using different attributes.
Highly reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
Interact and enhance learning
Multi-PC projection software allows teachers and students to share content simultaneously. The moderator function allows teachers to remain in control, choosing what content to display. Combine two projectors to create one large interactive display. Split-screen capability allows teachers to display two separate types of content simultaneously, such as a lesson plan from a PC and a still image or video clip from a document camera.
Optional wireless capability
Wirelessly display content easily from a range of smart devices and Google Chromebooks using our iProjection App.
  • High brightness and image quality
    Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than competitive projectors. With a scalable display size of up to 100 inches, two types of content can be displayed using the split-screen without compromising on quality.
  • Dual pen
  • Highly reliable
  • Interact and enhance learning
  • Optional wireless capability
Epson EB-675Wi - 3LCD projector - LAN - grey, white
3LCD projector - 720p
Grey, white
Built-in Devices
Speaker
Brightness (White)
3200 lumens
Brightness (Colour)
3200 lumens
Contrast Ratio
300:1 / 14000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
215 Watt
Video Input
RGB, composite video LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
311 Watt
36.7 cm x 40 cm x 14.9 cm
5.9 kg
3-year warranty
Built-in Devices
Speaker
Ethernet
Enclosure Colour
Grey, white
Projector
Brightness (White)
3200 lumens
Brightness (Colour)
3200 lumens
Brightness (Reduced)
1800 lumens
Contrast Ratio
Image Size
152 cm - 254 cm
Projection Distance
0.4 m - 0.6 m
Throw Ratio
0.28:1
Digital Zoom Factor
1.35x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
215 Watt
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Direct Power On, Direct Power Off, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode, Auto Calibration
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out
Pen tray, wireless remote control, pen case, interactive pens
1 x USB cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
311 Watt
Power Consumption Stand by
0.39 Watt
Software Included
Epson Easy Interactive Tools, EasyMP Monitor, EasyMP Multi PC Projection
36.7 cm
40 cm
14.9 cm
5.9 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
35 dBA
28 dBA
