Finger-touch projector
Quality image Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors1. WXGA resolution, that matches the resolution and aspect ratio of most laptop displays, and HDMI input mean that students benefit from sharp, clear projected images.
Finger-touch and dual pen
Use your fingers to annotate directly onto the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, teacher and student or two students can work simultaneously using different pen attributes.
Reliable
Project for longer with improved reliability and a longer lamp life of up to 6,000 hours.
Save time
Simply plug in and turn on - there's no warm-up time and the PC-free annotation mode means that teachers don't even need to power up their computers. The interactive function does not require drivers to be installed and it auto-calibrates.
Wireless projector
The wireless capability allows you to show content easily from a range of smart devices using the iProjection App2.
More control and collaboration
Multi-PC projection software allows teachers and students to share their content simultaneously. The moderator function allows teachers to remain in complete control since they can choose what content to display.
Key Features -Quality image Epson's 3LCD technology ensures high-quality images -Finger-touch and dual pen Use your fingers to annotate directly onto the screen -Reliable Improved reliability and a longer lamp life -Save time Simply plug in and turn on - there's no warm-up time -Wireless projector Wireless capability allows content to be shown from a range of devices
- Compared to leading 1-chip DLP business and education projectors based on NPD data, July 2011 through June 2012. Colour Brightness (Colour Light Output) measured in accordance with IDMS 15.4. Colour Brightness will vary depending on usage conditions. For more information please visit www.epson.eu/CLO 2 - iProjection App available on Android and iOS devices
Quality image
Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors. WXGA resolution, that matches the resolution and aspect ratio of most laptop displays, and HDMI input mean that students benefit from sharp, clear projected images. -
Use your fingers to annotate directly onto the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, teacher and student or two students can work simultaneously using different pen attributes. -
Reliable
Project for longer with improved reliability and a longer lamp life of up to 6,000 hours. -
Save time
Simply plug in and turn on – there's no warm-up time and the PC-free annotation mode means that teachers don't even need to power up their computers. The interactive function does not require drivers to be installed and it auto-calibrates. -
Wireless projector
The optional wireless capability allows you to show content easily from a range of smart devices using the iProjection App. -
- Epson EB 595Wi LCD projector
- LCD projector - High Definition
- Brightness (White)
- 3300 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- Widescreen
- Bulb type
- 245 Watt
- Bulb life cycle
- Up to 4000 hour(s) / up to 6000 hour(s) (economic mode)
- Video Input
- RGB, S-Video, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V ( 50 - 60 Hz )
- 358 Watt
- 36.7 cm x 37.5 cm x 15.5 cm
- 5.5 kg
- LCD projector - HD
- Networking
- Ethernet
Projector
- 3300 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 152 cm - 254 cm
- Throw Ratio
- 0.27:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- Widescreen
- Bulb type
- 245 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, 16:10 aspect ratio support, Dynamic Mode, Theater Mode, MHL compliance
Lens
- Focus Type
- Manual
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 2 x HDMI input - 19 pin HDMI Type A , VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 PIN USB Type A , 1 x composite video input - RCA , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 PIN USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5mm
- Included Accessories
- Wall mounting kit, Interactive Pen, remote control, pen case
- Cables Included
- 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Nominal Voltage
- 358 Watt
- Power Consumption Stand by
- 0.33 Watt
- Software Included
- Epson Easy Interactive Tools, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 36.7 cm
- 37.5 cm
- 15.5 cm
- 5.5 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
