Epson EB 585W WXGA 3LCD 3300 Lumens Install Projector
Quicklinx: 9PJFWS00 Mfr#: V11H602041
Quality image
Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors . WXGA resolution, that matches the resolution and aspect ratio of most laptop displays, and HDMI input mean that students benefit from sharp, clear projected images.
Reliable
Project for longer with improved reliability and a longer lamp life of up to 6,000 hours.
More control and collaboration
The multi-PC projection software allows teachers and students to share their content simultaneously. The moderator function allows teachers to remain in complete control since they can choose when to display student content – ideal for interaction in a collaborative teaching or training environment.
Save time
Simply plug in and turn on – there's no warm-up time, and with a wall-mounting bracket included in the box, it's easy to get started.
Wireless projector
The wireless capability allows you to share content easily from a range of smart devices using the iProjection App .
  • Ultra-short-throw
    Bring the classroom to life with our brightest ultra-short-throw, 3LCD projector.
Epson EB-585W - 3LCD projector - LAN
3LCD projector
Brightness (White)
3300 lumens
Brightness (Colour)
1900 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
245 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
358 Watt
36.7 cm x 37.5 cm x 15.5 cm
5.5 kg
3LCD projector
Ethernet
Projector
Brightness (White)
3300 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
152 cm - 254 cm
Throw Ratio
0.27:1
Digital Zoom Factor
1.35x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Display Format
1,024,000 pixels (1,280 x 800) x 3
Bulb type
245 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, 16:10 aspect ratio support, Dynamic Mode, Theater Mode, MHL compliance
Lens
Focus Type
Manual
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
2 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm
Wall mounting kit, remote control
1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
358 Watt
Power Consumption Stand by
0.33 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
36.7 cm
37.5 cm
15.5 cm
5.5 kg
5 °C
35 °C
20 - 80%
Sound Emission
35 dBA
28 dBA
9PJF C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
