Quality image
Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors . HDMI input means that students benefit from sharp, clear projected images.
Reliable
Project for longer with improved reliability and a longer lamp life of up to 6,000 hours.
More control and collaboration
The multi-PC projection software allows teachers and students to share their content simultaneously. The moderator function allows teachers to remain in complete control since they can choose when to display student content – ideal for interaction in a collaborative teaching or training environment.
Save time
Simply plug in and turn on – there's no warm-up time, and with a wall-mounting bracket included in the box, it's easy to get started.
Wireless projector
The wireless capability allows you to share content easily from a range of smart devices using the iProjection App .
- Epson EB-580 - 3LCD projector - LAN
- 3LCD projector
- Brightness (White)
- 3200 lumens
- Brightness (Colour)
- 1900 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 245 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 358 Watt
- 36.7 cm x 37.5 cm x 15.5 cm
- 5.3 kg
- 3LCD projector
- Networking
- Ethernet
Projector
- 3200 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 142 cm - 236 cm
- Throw Ratio
- 0.31:1
- Digital Zoom Factor
- 1.35x
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Bulb type
- 245 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Dynamic Mode, Theater Mode, MHL compliance
Lens
- Focus Type
- Manual
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 2 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm
- Included Accessories
- Wall mounting kit, remote control
- Cables Included
- 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Voltage Required
- 358 Watt
- Power Consumption Stand by
- 0.33 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 36.7 cm
- 37.5 cm
- 15.5 cm
- 5.3 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
