Epson EB-575Wi UST WXGA 2700 Lumens Interactive Projector
Quicklinx: 9JW8WS00 Mfr#: V11H601041
Quality image
Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors . WXGA resolution and HDMI input mean that students benefit from sharp, clear projected images.
Dual Pen Interactivity
Epson's interactive pens are now even more responsive and easy to use, with an improved design. Dual pen capability allows for simultaneous, collaborative learning with different pen attributes. The 'hover' function accurately detects the position of the pen when it's not in contact with the projection surface.
Reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours.
Save time
Simply plug in and turn on – there's no warm-up time and the PC-free annotation mode means that teachers don't even need to power up their computers. The interactive function does not require drivers to be installed and it auto-calibrates.
Wireless projector
The wireless capability allows you to show content easily from a range of smart devices using the iProjection App .
More control and collaboration
Multi-PC projection software allows teachers and students to share their content simultaneously. The moderator function allows teachers to remain in complete control since they can choose what content to display.
  • Interactive projector
    One of our brightest ultra-short-throw projectors yet, with dual pen interactivity and widescreen resolution.
Epson EB-575Wi - 3LCD projector - LAN
3LCD projector
Brightness (White)
2700 lumens
Brightness (Colour)
1500 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
215 Watt
Bulb life cycle
Up to 5000 hours - normal mode , Up to 10000 hours - economic mode
Video Input
RGB, S-Video, composite video LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
318 Watt
36.7 cm x 37.5 cm x 15.5 cm
5.5 kg
3LCD projector
Ethernet
Projector
Brightness (White)
2700 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
152 cm - 254 cm
Throw Ratio
0.27:1
Digital Zoom Factor
1.35x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
215 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, 16:10 aspect ratio support, Dynamic Mode, Theater Mode, integrate interactive functions, MHL compliance
Lens
Focus Type
Manual
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
2 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm
Wall mounting kit, Interactive Pen, remote control
1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
318 Watt
Power Consumption Stand by
0.33 Watt
Software Included
Epson Easy Interactive Tools, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
36.7 cm
37.5 cm
15.5 cm
5.5 kg
5 °C
35 °C
20 - 80%
Sound Emission
35 dBA
28 dBA
