Quality image
Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors . WXGA resolution and HDMI input mean that students benefit from sharp, clear projected images.
Dual Pen Interactivity
Epson's interactive pens are now even more responsive and easy to use, with an improved design. Dual pen capability allows for simultaneous, collaborative learning with different pen attributes. The 'hover' function accurately detects the position of the pen when it's not in contact with the projection surface.
Reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours.
Save time
Simply plug in and turn on – there's no warm-up time and the PC-free annotation mode means that teachers don't even need to power up their computers. The interactive function does not require drivers to be installed and it auto-calibrates.
Wireless projector
The wireless capability allows you to show content easily from a range of smart devices using the iProjection App .
More control and collaboration
Multi-PC projection software allows teachers and students to share their content simultaneously. The moderator function allows teachers to remain in complete control since they can choose what content to display.
Interactive projector
One of our brightest ultra-short-throw projectors yet, with dual pen interactivity and widescreen resolution.
- Epson EB-575Wi - 3LCD projector - LAN
- 3LCD projector
- Brightness (White)
- 2700 lumens
- Brightness (Colour)
- 1500 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 215 Watt
- Bulb life cycle
- Up to 5000 hours - normal mode , Up to 10000 hours - economic mode
- Video Input
- RGB, S-Video, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 318 Watt
- 36.7 cm x 37.5 cm x 15.5 cm
- 5.5 kg
- 3LCD projector
- Networking
- Ethernet
Projector
- 2700 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 152 cm - 254 cm
- Throw Ratio
- 0.27:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- 215 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, 16:10 aspect ratio support, Dynamic Mode, Theater Mode, integrate interactive functions, MHL compliance
Lens
- Focus Type
- Manual
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 2 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm
- Included Accessories
- Wall mounting kit, Interactive Pen, remote control
- Cables Included
- 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Voltage Required
- 318 Watt
- Power Consumption Stand by
- 0.33 Watt
- Software Included
- Epson Easy Interactive Tools, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 36.7 cm
- 37.5 cm
- 15.5 cm
- 5.5 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 28 dBA
