Quality image
Epson's 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors . WXGA resolution, that matches the resolution and aspect ratio of most laptop displays, and HDMI input mean that students benefit from sharp, clear projected images.
Reliable
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours.
More control and collaboration
The multi-PC projection software allows teachers and students to share their content simultaneously. The moderator function allows teachers to remain in complete control since they can choose when to display student content – ideal for interaction in a collaborative teaching or training environment.
Save time
Simply plug in and turn on – there's no warm-up time, and with a wall-mounting bracket included in the box, it's easy to get started.
Wireless projector
The wireless capability allows you to share content easily from a range of smart devices using the iProjection App .
Ultra-short-throw
Deliver lessons in confidence with one of our brightest ultra-short-throw, 3LCD projectors.
- Epson EB-575W - 3LCD projector - LAN
- 3LCD projector
- Brightness (White)
- 2700 lumens
- Brightness (Colour)
- 1500 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 215 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 318 Watt
- 36.7 cm x 37.5 cm x 15.5 cm
- 5.3 kg
- 3LCD projector
- Networking
- Ethernet
Projector
- 2700 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 152 cm - 254 cm
- Throw Ratio
- 0.27:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Display Format
- 1,024,000 pixels (1,280 x 800) x 3
- Bulb type
- 215 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, 16:10 aspect ratio support, Dynamic Mode, Theater Mode, MHL compliance
Lens
- Focus Type
- Manual
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -3 / +3
- Horizontal Keystone Correction
- -3 / +3
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 2 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm
- Included Accessories
- Wall mounting kit, remote control
- Cables Included
- 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Voltage Required
- 318 Watt
- Power Consumption Stand by
- 0.33 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 36.7 cm
- 37.5 cm
- 15.5 cm
- 5.3 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 28 dBA
