High-quality image
Complete with our 3LCD technology, the EB-536Wi displays superior-quality, bright images with more accurate colours. The image can be seen even in brightly-lit rooms thanks to an equally high white and colour light output. Image detail is clear thanks to a high contrast ratio and our new short throw lens means sharper images and improved focus.
More value for your money
The lamp in the EB-536Wi now lasts up to 10,000 hours in eco mode. The projector even conserves power during presentations by automatically adjusting the light output depending on the content. The A/V mute function pauses the presentation and dims the lamp by 70% to conserve energy while the projector is not in use. The projectors' built-in 16w speaker means audio content can be played directly through the projector, without the need for additional external speakers. The microphone input transforms the projector into a PA system, meaning presenters can be easily heard in a classroom environment.
Easy to use interactivity
Driverless installation and auto calibration makes setting up the EB-536Wi quick and easy. The EB-536Wi features dual pen capability, meaning two users can annotate across the entire screen area simultaneously using separate attributes . The interactive pens are now also faster-syncing and more accurate for smooth, precise writing. Easy Interactive Tools software provides users with a wide-range of interactive features.
Short- throw projector
This versatile interactive projector is ideal for delivering high-quality presentations in classrooms and small meeting rooms.
- Epson EB-536WI - 3LCD projector - LAN
- 3LCD projector - 720p
- Built-in Devices
- Speaker, 0.59-inch TFT LCD
- Brightness (White)
- 3400 lumens
- Brightness (Colour)
- 3400 lumens
- Contrast Ratio
- 16000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 215 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 298 Watt
- 34.4 cm x 31.5 cm x 9.4 cm
- 3.9 kg
- 2-year warranty
- Built-in Devices
- Networking
- Ethernet
Projector
- 3400 lumens
- 3400 lumens
- Brightness (Reduced)
- 1900 lumens
- Contrast Ratio
- 16000:1 (dynamic)
- Image Size
- 134 cm - 294 cm
- Projection Distance
- 0.5 m - 1.2 m
- Throw Ratio
- 0.48:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Bulb type
- 215 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- EPSON 3LCD technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -7 / +7
- Horizontal Keystone Correction
- -5/ +5
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 1 x HDMI input - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm , 2 x component video input , 1 x serial RS-232
- Included Accessories
- Remote control
- Security Features
- Voltage Required
- 298 Watt
- Power Consumption Stand by
- 0.28 Watt
- Software Included
- Epson Easy Interactive Tools, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 34.4 cm
- 31.5 cm
- 9.4 cm
- 3.9 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £101.71 |
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
Epson Wireless Adaptor LAN B/G/N | In Stock | £101.99 |
Epson ELPDC07 Digital Document Camera | In Stock | £180.47 |
