High-quality image
Complete with our 3LCD technology, the EB-530 displays superior-quality, bright images with more accurate colours. The image can be seen even in brightly-lit rooms thanks to an equally high white and colour light output. Image detail is clear thanks to a high contrast ratio and our new short throw lens means sharper images and improved focus.
More value for your money
The lamp in the EB-530 now lasts up to 10,000 hours in eco mode. The projector even conserves power during presentations by automatically adjusting the light output depending on the content. The A/V mute function pauses the presentation and dims the lamp by 70% to conserve energy while the projector is not in use. The projectors' built-in 16w speaker means audio content can be played directly through the projector, without the need for additional external speakers. The microphone input transforms the projector into a PA system, meaning presenters can be easily heard in a classroom environment.
Easy to set up and use
The EB-530 has both horizontal and vertical keystone correction to achieve a perfectly shaped image and help avoid distortion. When setting up several projectors, the OSD settings can be copied from one projector to many others meaning you don't need to set up projectors individually. Multi-PC projection software allows content from four devices, including PC's, tablets, smart phones, to be displayed simulatenously.
Short-throw projector
This versatile projector is ideal for delivering high-quality presentations in classrooms and small meeting rooms.
- Epson EB-530 - 3LCD projector - LAN
- 3LCD projector
- Built-in Devices
- Speaker, 0.55-inch TFT LCD
- Brightness (White)
- 3200 lumens
- Brightness (Colour)
- 3200 lumens
- Contrast Ratio
- 16000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 215 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 298 Watt
- 34.4 cm x 31.5 cm x 9.4 cm
- 3.7 kg
- 2-year warranty
- 3LCD projector
- Built-in Devices
- Networking
- Ethernet
Projector
- 3200 lumens
- Contrast Ratio
- 16000:1 (dynamic)
- Image Size
- 127 cm - 274 cm
- Projection Distance
- 0.5 m - 1.3 m
- Throw Ratio
- 0.55:1
- Digital Zoom Factor
- 1.35x
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- 215 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- EPSON 3LCD technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.6
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -15 / +15
- Horizontal Keystone Correction
- -15 / +15
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 1 x HDMI input - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x microphone - mini-phone 3.5 mm , 2 x component video input , 1 x serial RS-232
- Included Accessories
- Remote control
- Security Features
- Voltage Required
- 298 Watt
- Power Consumption Stand by
- 0.28 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 34.4 cm
- 31.5 cm
- 9.4 cm
- 3.7 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 28 dBA
Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) | In Stock | £96.86 |
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
Epson ELPDC07 Digital Document Camera | In Stock | £180.47 |
