The EB-4650 boasts high definition picture quality and a 5,000:1 contrast ratio. This helps showcase your important presentations and other projections in the best possible way.
Thanks to a variety of user-friendly installation features, this projector is easy to set up and use. Its x2.0 wide zoom ratio, as well as keystone correction, and arc and point correction, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
With the HDMI input and Display Port, you can connect a variety of high definition devices to project your content effortlessly. In addition, the lamp and filter are easy to replace, helping keep maintenance straightforward and ensuring your projections are as bright and clear as possible.
While presenting, the side-by-side split screen function allows you present from two different sources, such as a separate laptop, for much more in-depth and impressive presentations.
Installation projector
The 5,200-lumen installation projector, with XGA resolution, for bright, clear images.
- Epson EB-4650 - 3LCD projector
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness (White)
- 5200 ANSI lumens
- Brightness (Colour)
- 5200 lumens
- Contrast Ratio
- 5000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 280 Watt
- Bulb life cycle
- Up to 4000 hours - normal mode , Up to 6000 hours - economic mode
- Video Input
- RGB, S-Video, composite video
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 388 Watt
- 47.2 cm x 35.4 cm x 15.9 cm
- 6.6 kg
- 2-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- 5200 ANSI lumens
- 5200 lumens
- Contrast Ratio
- 5000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.7 m - 15.9 m
- Throw Ratio
- 1.27 - 2.59:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Bulb type
- 280 Watt
- Bulb life cycle
- sRGB colour profile, EPSON 3LCD technology, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.5-2.14
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 58% / 58%
- Horizontal Lens Shift
- 38% / 38%
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, component video, composite video, S-Video
Speakers
- Integrated
- Output Power / Channel
- 10 Watt
- 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x composite video input - RCA , 1 x component video input - BNC , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Voltage Required
- 388 Watt
- Power Consumption Stand by
- 0.39 Watt
- Software Included
- Drivers & Utilities, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 47.2 cm
- 35.4 cm
- 15.9 cm
- 6.6 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 20 - 80%
- Sound Emission
- 38 dBA
- Sound Emission (Economic Mode)
- 32 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
