Epson EB-4650 XGA 3LCD 5200 Lumens Projector
Quicklinx: 96Q1WS00 Mfr#: V11H546041
The EB-4650 boasts high definition picture quality and a 5,000:1 contrast ratio. This helps showcase your important presentations and other projections in the best possible way.
Thanks to a variety of user-friendly installation features, this projector is easy to set up and use. Its x2.0 wide zoom ratio, as well as keystone correction, and arc and point correction, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
With the HDMI input and Display Port, you can connect a variety of high definition devices to project your content effortlessly. In addition, the lamp and filter are easy to replace, helping keep maintenance straightforward and ensuring your projections are as bright and clear as possible.
While presenting, the side-by-side split screen function allows you present from two different sources, such as a separate laptop, for much more in-depth and impressive presentations.
  • Installation projector
    The 5,200-lumen installation projector, with XGA resolution, for bright, clear images.
Epson EB-4650 - 3LCD projector
3LCD projector
Built-in Devices
Speaker
Brightness (White)
5200 ANSI lumens
Brightness (Colour)
5200 lumens
Contrast Ratio
5000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens Shift Direction
Horizontal, vertical
Bulb type
280 Watt
Bulb life cycle
Up to 4000 hours - normal mode , Up to 6000 hours - economic mode
Video Input
RGB, S-Video, composite video
Speakers
Speaker(s) - integrated
388 Watt
47.2 cm x 35.4 cm x 15.9 cm
6.6 kg
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness (White)
5200 ANSI lumens
Brightness (Colour)
5200 lumens
Contrast Ratio
5000:1
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 15.9 m
Throw Ratio
1.27 - 2.59:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
280 Watt
Bulb life cycle
sRGB colour profile, EPSON 3LCD technology, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.5-2.14
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Manual
Vertical Lens Shift
58% / 58%
Horizontal Lens Shift
38% / 38%
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, component video, composite video, S-Video
Speakers
Integrated
Output Power / Channel
10 Watt
1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x composite video input - RCA , 1 x component video input - BNC , 1 x S-video input , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
388 Watt
Power Consumption Stand by
0.39 Watt
Software Included
Drivers & Utilities, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
47.2 cm
35.4 cm
15.9 cm
6.6 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
20 - 80%
Sound Emission
38 dBA
32 dBA
96Q1 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
