Epson EB-2265U 5500 ANSI Lumens WUXGA 3LCD Technology 4.9Kg
Quicklinx: D92YWS00 Mfr#: V11H814041
Portability: Non-portable
Hurry, only 3 left in stock!
£1,842.73 ex VAT
£2,211.27 inc VAT
The Epson EB-2265U Office / Desktop uses LCD technology to product a 1920*1200 resolution image with a brightness of 5500 and 15000:1 contrast ratio.
  • Hassle-free connectivity and setup
    The EB-2265U has wireless connectivity as standard to give you enhanced freedom and flexibility. Support for HDBaseT provides Full-HD video, audio and Ethernet, while the HDBaseT cable allows control from 100 meters away in networks installed with Category 5e cable and above. A smart solution for large venues.
  • Gesture Presenter
    The projector can be manipulated by simply moving your hand in front of it, making smarter, smoother presentations an instant reality.
  • One-button setup
    Thanks to the EB-2265U's one-button setup, making adjustments to screen fit and vertical or horizontal keystone correction are quick, simple and require no expert training.
Epson EB-2265U - LCD projector - 802.11n wireless / LAN / Miracast
LCD projector - 1080p
White
Brightness (White)
5500 lumens
Brightness (Colour)
5500 lumens
Contrast Ratio
400:1 / 15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
300 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video IEEE 802.11n wireless / LAN / Miracast
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
450 Watt
37.7 cm x 29.1 cm x 11 cm
4.9 kg
3-year warranty
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
5500 lumens
Brightness (Colour)
5500 lumens
Brightness (Reduced)
3800 lumens
Contrast Ratio
Image Size
127 cm - 762 cm
Projection Distance
1.5 m - 9 m
Throw Ratio
1.38 - 2.28:1
Digital Zoom Factor
1.6x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Bulb type
300 Watt
Bulb life cycle
sRGB colour profile, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
Focus Type
Manual
Lens Aperture
F/1.5-2.0
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 2 x HDMI - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45
Wireless remote control, wireless LAN unit
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
Nominal Voltage
450 Watt
Power Consumption Stand by
0.5 Watt
Software Included
EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
37.7 cm
29.1 cm
11 cm
4.9 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
29 dBA
Brand: Epson
Price Range Ex VAT: 1500+
