Epson EB-2265U 5500 ANSI Lumens WUXGA 3LCD Technology 4.9Kg
Quicklinx: D92YWS00 Mfr#: V11H814041
Portability: Non-portable
27 in stock
£1,003.09 ex VAT
£1,203.70 inc VAT
The Epson EB-2265U Office / Desktop uses LCD technology to product a 1920*1200 resolution image with a brightness of 5500 and 15000:1 contrast ratio.
  • Outstanding quality display of up to 300 inches
    Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. Versatile connectivity guarantees sharper and clearer presentations delivered on a scalable image size of up to 300 inches.
  • HDBaseT connectivity
    The EB-2265U offers a wide range of connectivity options, including HDBaseT, screen mirroring, wireless LAN and two HDMI inputs. HDBaseT provides Full HD video, audio and Ethernet connectivity via one cable to enable efficient control from 100m away.
  • Home screen
    The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on the screen.
  • Gesture Presenter
    Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse.
  • Auto Power On
    The projector will start-up automatically upon connecting an HDMI, VGA, or USB cable, meaning you no longer have to use the power button on the remote control.
  • Value-added flexibility
    The Multi-PC projection software bundled with the EB-2265U makes it possible to connect up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Epson EB-2265U - LCD projector - 802.11n wireless / LAN / Miracast
LCD projector - 1080p
White
Brightness (White)
5500 lumens
Brightness (Colour)
5500 lumens
Contrast Ratio
400:1 / 15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
300 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video IEEE 802.11n wireless / LAN / Miracast
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
450 Watt
37.7 cm x 29.1 cm x 11 cm
4.9 kg
3-year warranty
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
5500 lumens
Brightness (Colour)
5500 lumens
Brightness (Reduced)
3800 lumens
Contrast Ratio
Image Size
127 cm - 762 cm
Projection Distance
1.5 m - 9 m
Throw Ratio
1.38 - 2.28:1
Digital Zoom Factor
1.6x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Bulb type
300 Watt
Bulb life cycle
sRGB colour profile, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
Focus Type
Manual
Lens Aperture
F/1.5-2.0
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 2 x HDMI - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45
Wireless remote control, wireless LAN unit
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
Nominal Voltage
450 Watt
Power Consumption Stand by
0.5 Watt
Software Included
EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
37.7 cm
29.1 cm
11 cm
4.9 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
29 dBA
Brand: Epson
Price Range Ex VAT: 1000 - 1500
