Epson EB-2255U WUXGA 3LCD 5000 Lumens Projector
Quicklinx: FB5HWS00 Mfr#: V11H815041
Portability: Non-portable
£1,819.69 ex VAT
£2,183.62 inc VAT
Deliver Full HD presentations to bring sharp images and bright colours to any meeting room with our super-bright business projector. The EB-2255U is designed to project a scalable image up to a massive 300 inches, and offers a range of connectivity options including screen mirroring and Wireless LAN connectivity.
  • Outstanding quality display of up to 300 inches
    Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer presentations delivered on a scalable image size of up to 300 inches.
  • Simple setup and multiple connectivity
    The EB-2255U offers a wide range of connectivity options, including screen mirroring, wireless LAN and two HDMI inputs. Setup is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - delivering presentations quickly and efficiently.
  • Highly reliable
    Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
  • Home screen
    The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on the screen.
  • Gesture Presenter
    Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse.
  • Value-added flexibility
    The Multi-PC projection software bundled with the EB-2255U makes it possible to connect up to 50 computers and partition the screen for split screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Epson EB-2255U - LCD projector - 802.11b/g/n wireless / LAN / Miracast / Intel Wireless Display (WiDi) - white
LCD projector - 1080p
White
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
400:1 / 15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
300 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
IEEE 802.11b/g/n wireless / LAN / Miracast / Intel Wireless Display (WiDi)
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
420 Watt
37.7 cm x 29.1 cm x 11 cm
4.9 kg
3-year warranty
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Brightness (Reduced)
3800 lumens
Contrast Ratio
Image Size
127 cm - 762 cm
Projection Distance
1.5 m - 9 m
Throw Ratio
1.38 - 2.28:1
Digital Zoom Factor
1.6x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Bulb type
300 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
Focus Type
Manual
Lens Aperture
F/1.5-2.0
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, WiDi, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDBaseT - RJ-45
Wireless remote control, wireless LAN unit
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
420 Watt
Power Consumption Stand by
0.5 Watt
Software Included
EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
37.7 cm
29.1 cm
11 cm
4.9 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
29 dBA
Brand: Epson
Price Range Ex VAT: £1500+
