Epson EB-2247U 3LCD WUXGA 4200 Lumens Projector
Quicklinx: DN0NWS00 Mfr#: V11H881041
Portability: Non-portable
11 in stock
£992.93 ex VAT
£1,191.51 inc VAT
Outstanding quality display of up to 300 inches
Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer presentations delivered on a scalable image size of up to 300 inches.
Simple set-up and multiple connectivity
The EB-2247U offers a wide range of connectivity options, including screen mirroring, wireless LAN and two HDMI inputs. Set-up is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - delivering presentations quickly and efficiently. Compatible with iProjection software for easy connectivity with mobile devices.
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as choosing connection sources. Wireless connections can also be made easily using the information on screen.
Value-added flexibility
The Multi-PC projection software bundled with the EB-2247U makes it possible to connect up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
  • Full HD business projector
    Deliver perfect Full HD presentations with this display solution, offering a brightness of 4,200 lumens with wireless and screen mirroring connectivity.
Epson EB-2247U - 3LCD projector - 802.11n wireless / LAN
3LCD projector - 1080p
White
Brightness (White)
4200 lumens
Brightness (Colour)
4200 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
230 Watt
Bulb life cycle
Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input
RGB, composite video, component video IEEE 802.11n wireless / LAN
Speakers
Speaker(s) - integrated
Environmental Standards
TCO Certified Projectors 2
AC 230V (50 - 60 Hz)
331 Watt
30.9 cm x 28.2 cm x 9 cm
3.2 kg
3-year warranty
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
4200 lumens
Brightness (Colour)
4200 lumens
Brightness (Reduced)
2410 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
1.5 m - 8.9 m
Throw Ratio
1.39 - 2.23:1
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
240 Hz
Bulb type
230 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.5-2.0
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x microphone input - mini-phone 3.5 mm
Wireless remote control, wireless LAN unit
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
TCO Certified
Power Source
AC
Nominal Voltage
331 Watt
Power Consumption Stand by
2 Watt
Software Included
EasyMP Multi PC Projection
30.9 cm
28.2 cm
9 cm
3.2 kg
Limited warranty - 3 years / 8000 hours , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
29 dBA
Brand: Epson
Price Range Ex VAT: 750 - 1000
