The Epson EB-2165W - 802.11b/g/n wireless / LAN / Miracast 3LCD projector will integrate learning in any environment and enhance collaboration. This innovative multifunction projector allows users to print, save, and share with ease thanks to the intuitive control pad. It comes with a three-year warranty.
You can use an interactive pen to write or make annotations on the screen. The remote location connectivity makes it simple to invite and share information with participants who are based elsewhere. The Epson EB-2165W - 802.11b/g/n wireless / LAN / Miracast 3LCD projector offers a range of features, including split-screen functionality, password protection, and automatic keystone correction.
Up to 300-inch display and outstanding quality
WXGA resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 300 inches. -
HDBaseT Connectivity
The EB-2165W offers a wide range of connectivity options, including HDBaseT, Screen Mirroring, two HDMI inputs, and Wireless LAN connectivity for PCs and mobile devices. HDBaseT provides Full HD video, audio and Ethernet connectivity via one cable to enable control from 100 metres away. -
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on screen. -
Gesture Presenter
Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse . -
Auto Power On
The projector will start-up automatically upon connecting an HDMI, VGA, or USB cable to the connected device, meaning you no longer have to use the power button on the remote control. -
Value-added flexibility
The Multi-PC projection software bundled with the EB-2250U makes it possible to connect up to 50 computers and partition the screen for split screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
- Epson EB-2165W - 3LCD projector - 802.11b/g/n wireless / LAN / Miracast - white
- 3LCD projector - 720p
- White
- Brightness (White)
- 5500 lumens
- Brightness (Colour)
- 5500 lumens
- Contrast Ratio
- 400:1 / 15000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 300 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- IEEE 802.11b/g/n wireless / LAN / Miracast
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 450 Watt
- 37.7 cm x 29.1 cm x 10.1 cm
- 4.8 kg
- 3-year warranty
- Networking
- 802.11b/g/n, Ethernet
- Enclosure Colour
- White
Projector
- 5500 lumens
- 5500 lumens
- Brightness (Reduced)
- 3800 lumens
- Contrast Ratio
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.9 m - 9 m
- Throw Ratio
- 1.38 - 2.28:1
- Digital Zoom Factor
- 1.6x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Bulb type
- 300 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDBaseT - RJ-45
- Included Accessories
- Wireless remote control, wireless LAN unit
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Power Source
- AC
- Voltage Required
- 450 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 29.1 cm
- 10.1 cm
- 4.8 kg
- Limited warranty - 3 years / 8000 hours - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 39 dBA
- Sound Emission (Economic Mode)
- 29 dBA
Epson ELPMB23 Projector Mount | In Stock | £109.44 |
Epson Wireless Adaptor LAN B/G/N | In Stock | £101.99 |
