Epson EB-2165W WXGA 3LCD 5500 Lumens Projector
Quicklinx: CW1CWS00 Mfr#: V11H817041
The Epson EB-2165W - 802.11b/g/n wireless / LAN / Miracast 3LCD projector will integrate learning in any environment and enhance collaboration. This innovative multifunction projector allows users to print, save, and share with ease thanks to the intuitive control pad. It comes with a three-year warranty.
You can use an interactive pen to write or make annotations on the screen. The remote location connectivity makes it simple to invite and share information with participants who are based elsewhere. The Epson EB-2165W - 802.11b/g/n wireless / LAN / Miracast 3LCD projector offers a range of features, including split-screen functionality, password protection, and automatic keystone correction.
  • Up to 300-inch display and outstanding quality
    WXGA resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 300 inches.
  • HDBaseT Connectivity
    The EB-2165W offers a wide range of connectivity options, including HDBaseT, Screen Mirroring, two HDMI inputs, and Wireless LAN connectivity for PCs and mobile devices. HDBaseT provides Full HD video, audio and Ethernet connectivity via one cable to enable control from 100 metres away.
  • Home screen
    The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on screen.
  • Gesture Presenter
    Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse .
  • Auto Power On
    The projector will start-up automatically upon connecting an HDMI, VGA, or USB cable to the connected device, meaning you no longer have to use the power button on the remote control.
  • Value-added flexibility
    The Multi-PC projection software bundled with the EB-2250U makes it possible to connect up to 50 computers and partition the screen for split screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Epson EB-2165W - 3LCD projector - 802.11b/g/n wireless / LAN / Miracast - white
3LCD projector - 720p
White
Brightness (White)
5500 lumens
Brightness (Colour)
5500 lumens
Contrast Ratio
400:1 / 15000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
300 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
IEEE 802.11b/g/n wireless / LAN / Miracast
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
450 Watt
37.7 cm x 29.1 cm x 10.1 cm
4.8 kg
3-year warranty
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
5500 lumens
Brightness (Colour)
5500 lumens
Brightness (Reduced)
3800 lumens
Contrast Ratio
Image Size
76 cm - 762 cm
Projection Distance
0.9 m - 9 m
Throw Ratio
1.38 - 2.28:1
Digital Zoom Factor
1.6x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
300 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDBaseT - RJ-45
Wireless remote control, wireless LAN unit
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
450 Watt
Power Consumption Stand by
0.5 Watt
Software Included
EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
37.7 cm
29.1 cm
10.1 cm
4.8 kg
Limited warranty - 3 years / 8000 hours - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
29 dBA
