Epson EB-2155W WXGA 3LCD 5000 Lumens Projector
Quicklinx: DQW0WS00 Mfr#: V11H818041
Portability: Non-portable
£1,120.29 ex VAT
£1,344.34 inc VAT
Our super-bright new business projector offers an outstanding brightness of 5,000 lumens. The EB-2155W is designed to project a scalable image size of up to 300 inches, and offers connectivity options such as dual HDMI and stream and share wireless features using Epson's Multi-PC projection or the Epson iProjection App.
  • Up to 300-inch display and outstanding quality
    Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer presentation delivered on a scalable image size of up to 300 inches.
  • Simple setup and connectivity
    The EB-2155W offers stream and share wireless LAN connectivity using Epson's Multi-PC projection or the Epson iProjection App, as well as two HDMI connections. Setup is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - allowing the user to delivery presentations quickly and effectively.
  • Keep costs down
    Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode.
  • Home screen
    The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on screen.
  • Gesture Presenter
    Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse.
  • Value add flexibility
    The Multi-PC projection software bundled with the EB-2155W makes it possible to connect with up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Epson EB-2155W - 3LCD projector - 802.11n wireless / LAN
3LCD projector - 720p
White
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
400:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
300 Watt
Video Input
RGB, composite video IEEE 802.11n wireless / LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
420 Watt
4.5 kg
3-year warranty
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Brightness (Reduced)
3600 lumens
Contrast Ratio
400:1
Image Size
74 cm - 711 cm
Projection Distance
0.9 m - 8.5 m
Throw Ratio
1.38 - 2.24:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
300 Watt
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode, instant on/off
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI
Wireless remote control, wireless LAN unit
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
Nominal Voltage
420 Watt
Power Consumption Stand by
0.5 Watt
Software Included
EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
4.5 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
29 dBA
Brand: Epson
Price Range Ex VAT: £1000 - £1500
