Bring sharp images and bright colours to any meeting room with our super-bright new business projector, which offers an outstanding brightness level of 5,500 lumens and XGA resolution. The EB-2065 is designed to project a scalable image up to a massive 300 inches, and offers stream and share wireless connectivity using Epson's Multi-PC projection or the Epson iProjection App.
Up to 300-inch display and outstanding quality
Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 300 inches. -
Simple setup and connectivity
The EB-2065 offers stream and share wireless LAN connectivity using Epson's Multi-PC projection or our Epson iProjection App and two HDMI connections. Setup is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - allowing the user to deliver presentations quickly and effectively. -
Keep costs down
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode. -
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on screen. -
Gesture Presenter
Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse. -
Value-added flexibility
The Multi-PC projection software bundled with the EB-2065 makes it possible to connect up to 50 computers and partition the screen for split screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
- Epson EB-2065 - LCD projector - LAN - white
- LCD projector
- White
- Brightness (White)
- 5500 lumens
- Brightness (Colour)
- 5500 lumens
- Contrast Ratio
- 400:1 / 15000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 300 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 440 Watt
- 37.7 cm x 29.1 cm x 10.1 cm
- 4.5 kg
- 3-year warranty
- LCD projector
- Networking
- Ethernet
- Enclosure Colour
- White
Projector
- 5500 lumens
- 5500 lumens
- Brightness (Reduced)
- 3800 lumens
- Contrast Ratio
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.8 m - 8.5 m
- Throw Ratio
- 1.38 - 2.24:1
- Digital Zoom Factor
- 1.6x
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- 300 Watt
- Bulb life cycle
- sRGB colour profile, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video, MHL
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Power Source
- AC
- Voltage Required
- 440 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 29.1 cm
- 10.1 cm
- 4.5 kg
- Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 39 dBA
- Sound Emission (Economic Mode)
- 29 dBA
Epson ELPMB23 Projector Mount | In Stock | £109.44 |
Epson Wireless Adaptor LAN B/G/N | In Stock | £101.99 |
