Bring sharp images and bright colours to any meeting room with our super-bright new business projector, which offers an outstanding brightness level of 5,000 lumens and XGA resolution. The EB-2055 is designed to project a scalable image up to a massive 300 inches, and offers stream and share wireless connectivity using Epson's Multi-PC projection or the Epson iProjection App. Up to 300-inch display and outstanding quality Epson’s 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 300 inches. Simple setup and connectivity The EB-2055 offers stream and share wireless LAN connectivity using Epson's Multi-PC projection or our Epson iProjection App and two HDMI connections. Setup is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - allowing the user to deliver presentations quickly and effectively.
Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 300 inches. -
The EB-2055 offers stream and share wireless LAN connectivity using Epson's Multi-PC projection or our Epson iProjection App and two HDMI connections. Setup is easy too, thanks to features including auto-power-on, focus help, keystone correction and screen fit - allowing the user to deliver presentations quickly and effectively. -
Keep costs down
Project for longer with improved reliability and a longer lamp life of up to 10,000 hours in eco mode. -
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on screen. -
Gesture Presenter
Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse. -
Value-added flexibility
The Multi-PC projection software bundled with the EB-2055 makes it possible to connect up to 50 computers and partition the screen for split screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
- Epson EB-2055 - 3LCD projector - 802.11 b/g/n wireless / LAN - white
- 3LCD projector
- White
- Brightness (White)
- 5000 lumens
- Brightness (Colour)
- 5000 lumens
- Contrast Ratio
- 400:1 / 15000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 300 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video IEEE 802.11 b/g/n wireless / LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 410 Watt
- 37.7 cm x 29.1 cm x 10.1 cm
- 4.5 kg
- 3-year warranty
- 3LCD projector
- Networking
- 802.11b/g/n, Ethernet
- Enclosure Colour
- White
Projector
- 5000 lumens
- 5000 lumens
- Brightness (Reduced)
- 3800 lumens
- Contrast Ratio
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.8 m - 8.5 m
- Throw Ratio
- 1.38 - 2.24:1
- Digital Zoom Factor
- 1.6x
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- 300 Watt
- Bulb life cycle
- sRGB colour profile, freeze frame, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x composite video input - RCA , 1 x USB 2.0 - 4 pin USB Type B (management) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 1 x serial RS-232C , 1 x USB 2.0 - 4 pin USB Type A , 1 x Mobile High-Definition Link (MHL) / HDMI
- Included Accessories
- Wireless remote control, wireless LAN unit
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Power Source
- AC
- Voltage Required
- 410 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 29.1 cm
- 10.1 cm
- 4.5 kg
- Limited warranty - 3 years / 8000 hours - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 39 dBA
- Sound Emission (Economic Mode)
- 29 dBA
