High quality
Professional environments are treated to presentations in more detail than ever before thanks to the EB-1985WU's WUXGA resolution, which fits the resolution and aspect ratio of most laptops. That detail shines through, even in daylight, thanks to 4,800 lumens brightness.
More vivid colours
Epson's own 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors .
Easy to set up
Focus help, keystone correction and screen fit modes are included to ensure that set-up is simple, while flexible connectivity options include two HDMI ports, Wi-Fi and wired LAN.
Share content
With Miracast and WiDi, the EB-1985WU can easily stream content from, and mirror the screen of, a range of smart devices, and is compatible with Epson's iProjection app . Content, such as a multi-source video conference and presentations, can be displayed in split-screen, while Multi-PC Projection software supports up to 50 PCs for collaboration in large meetings.
Built-in speakers
Epson recognises that video is being used more often within presentations, so as well as a high-resolution image, this business projector also includes built-in 16W speakers.
Bright business projector
This easy-to-set-up projector features WUXGA resolution, 4,800 lumens and 3LCD technology to create colourful and precise images.
- Epson EB 1985WU LCD projector
- LCD projector - High Definition 1080p
- Brightness (White)
- 4800 lumens
- Brightness (Colour)
- 4800 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- Widescreen
- Bulb type
- 280 Watt
- Bulb life cycle
- Up to 3000 hour(s) / up to 4000 hour(s) (economic mode)
- Video Input
- RGB, composite video, component video IEEE 802.11n wireless / LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V ( 50 - 60 Hz )
- 37.7 cm x 29.2 cm x 12.5 cm
- 4.5 kg
- 3 years warranty
- LCD projector - HD 1080p
- Networking
- 802.11b/g/n
Projector
- 4800 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 127 cm - 762 cm
- Projection Distance
- 1.5 m - 14.8 m
- Throw Ratio
- 1.38 - 2.28:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- Widescreen
- Bulb type
- 280 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Split Screen, 16:10 aspect ratio support, DICOM Simulation Mode, Dynamic Mode, Theater Mode, MHL compliance
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, MHL
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 PIN USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 1 x USB - 4 PIN USB Type B
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Nominal Voltage
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 29.2 cm
- 12.5 cm
- 4.5 kg
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years / 8000 hours , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 39 dB
- Sound Emission (Economic Mode)
- 32 dB
