High quality
Professional environments are treated to presentations in more detail than ever before thanks to the EB-1970W's WXGA resolution, which fits the resolution and aspect ratio of most laptops. That detail shines through thanks to 5,000 lumens brightness.
More vivid colours
Epson's own 3LCD technology ensures high-quality images with equally high White and Colour Light Output for vivid colours and bright images, even in daylight, and three times brighter colours than leading competitive projectors .
Easy to set up
Focus help, keystone correction and screen fit modes are included to ensure that set-up is simple, while flexible connectivity options include two HDMI ports, Wi-Fi and wired LAN.
Share content
Content, such as a multi-source video conference and presentations, can be displayed in split-screen, while Multi-PC Projection software supports up to 50 PCs for collaboration in large meetings.
Built-in speakers
Epson recognises that video is being used more often within presentations, so as well as a high-resolution image, this business projector also includes built-in 16W speakers.
Bright business projector
The easy-to-set-up EB-1970W projector boasts WXGA resolution, 5,000 lumens and 3LCD technology to create colourful and precise images.
- Epson EB-1970W - 3LCD projector - 802.11n wireless / LAN
- 3LCD projector
- Brightness (White)
- 5000 lumens
- Brightness (Colour)
- 5000 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 280 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video IEEE 802.11n wireless / LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 37.7 cm x 29.2 cm x 12.5 cm
- 4.5 kg
- 3-year warranty
- 3LCD projector
- Networking
- 802.11b/g/n
Projector
- 5000 lumens
- Contrast Ratio
- 10000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.9 m - 14.8 m
- Throw Ratio
- 1.38 - 2.28:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- 280 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Split Screen, 16:10 aspect ratio support, DICOM Simulation Mode, Dynamic Mode, Theater Mode, MHL compliance
Lens
- Focus Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, MHL
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type B
- Included Accessories
- Remote control
- Voltage Required
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 29.2 cm
- 12.5 cm
- 4.5 kg
- Limited warranty - 3 years / 8000 hours - carry-in , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 39 dB
- Sound Emission (Economic Mode)
- 32 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
