Convenient use
The Epson EB-1960 combines high-quality output, value-added features and affordability, into a compact and portable projector. It is perfect for corporate or educational use, as it can be easily installed in meeting rooms or used portably from a desktop.
High quality picture
Utilising Epson's 3LCD technology to ensure clearly projected images, the EB-1960 produces vivid, natural colours and an equally high White and Colour Light Output, even in daylight.
The EB-1960 boasts a DisplayPort connector, allowing you to show high definition audio and video content with ease.
Enhanced productivity
Productivity can be greatly increased with a range of features available with the EB-1960, such as Quick Corner.
- Epson EB-1960 - 3LCD projector - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet, Fast Ethernet
- Brightness
- 5000 lumens
- Brightness (Colour)
- 5000 lumens
- Contrast Ratio
- 3000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 245 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI), DisplayPort
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 720i, 526i, 526p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 337 Watt
- 37.7 cm x 10.8 cm x 27.1 cm
- 3.8 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Data Link Protocol
Projector
- Brightness
- 5000 lumens
- 5000 lumens
- Brightness (Reduced)
- 3470 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.8 m - 13.9 m
- Throw Ratio
- 1.38 - 2.24:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Display Format
- 786,432 pixels (1,024 x 768) x 3
- Bulb type
- 245 Watt
- Bulb life cycle
- sRGB colour profile, freeze frame, Blackboard Mode, JPEG photo playback, USB host function, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x DisplayPort - 20 pin DisplayPort , 1 x audio line-in - RCA x 2
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
- Voltage Required
- 337 Watt
- Power Consumption Operational (Standby)
- 0.44 Watt
- Software Included
- Drivers & Utilities, EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 10.8 cm
- 27.1 cm
- 3.8 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
